Thread: MMI Define Primary User
Results 1 to 10 of 13
  1. MMI Define Primary User
    Jun 2016
    London, uk
    One more question for my Q7...
    I am being told by the myAudi portal that I need to become the primary user for my car, it says:
    "You must enter your myAudi user name and the vehicle code in the MMI to become the primary user for your vehicle. The code provides proof of ownership and enables the use of vehicle safety services.
    You can find the vehicle code under an opaque security laminate on the key chain you received with your keys at vehicle handover. You can scratch off the laminate using a hard object and input the 10-digit vehicle code, together with your myAudi user name, in the MMI under “Audi connect > Audi connect User Management > Primary User > Define Primary User"
    I have got the code from the scratch off bit, but cannot get to a menu that says "Audi connect User Management > Primary User >".
    Any ideas how to get to this menu? I can get to a menu allowing me to log in, but nothing about a primary user, and if I use my email address and the code from the scratch off panel it does not work, if i use my total password it does, but then I guess I am not a 'primary user'.
    This is not very simple...
  2. Re: MMI Define Primary User
    Apr 2016
    berkshire
    39 Post(s)
    When you logged into myaudi abd2 added your vehicle via the VIN after you added your car are there any bits that require you to agree to certain terms within the portal.. I'm currently getting it but didn't accept it as i haven't received the car.. Still stuck in transit
    My thinking is it could be assiciated with remote features introduced with MY17 but I'm betting I could be wrong
    Sent from my LG-H961N using Tapatalk
  3. Re: MMI Define Primary User
    Apr 2016
    berkshire
    39 Post(s)
    apparently only Audi and the owner have access to it.
  4. Re: MMI Define Primary User
    Nov 2008
    Not relevant for UK market I believe as we set this up through entering your VIN on the myaudi website
    Sent from my SM-G935F using Tapatalk
    2012 Audi A7 SE, Midnight Blue, MMI Plus with touch, Adaptive Cruise Control, Lane Assist, Blind Spot Monitoring, Head Up Display, Audi Pre-Sense, 2wd 8 speed.
  5. Re: MMI Define Primary User
    Oct 2015
    Derby
    That menu is missing from current UK specification cars so features such as remote unlock, heating etc aren't available through the app. I imagine the MY17 cars will have it enabled. Even following all the steps online with the mtan code and agreement.
    Maybe Audi will enable it for all but I doubt it.
  6. Re: MMI Define Primary User
    Dec 2012
    Frome, Somerset
    So I have just taken delivery of a A4 Avant s line with Technology Pack etc. Same problem as rob_idn, cannot get to that part of the MMI and believe me I have tried very hard, will quivery not with the dealer but the MMI connect app is very hobbled compared to the demo mode which allowed all the vehicle control functionality. I cannot see what Audi would go to all the bother of putting this in the manual and sending me instruction emails if they weren't going to enable the functionality.
  7. Re: MMI Define Primary User
    Apr 2016
    6 Post(s)
    This is all very convoluted, but here are the exact steps I went through:
    1) Register MyAudi Account
    2) Add vehicle using VIN and generate 8 digit code
    3) Authorise account on MyAudi website by going to connect services>audi connect user management> completing the 5 step process and entering the mTAN authorisation code.
    4) In the MMI - Connect>right click to get sub menu>login> alternative login using PIN> enter 8 digit code.
    5) In the MMI - Connect>right click to get sub menu>manage key user(cannot remember exactly what this is called, but it is the last option in this context menu)> enter MyAudi user name and 10 digit code from scratch-off keyfob.
    If at any time you get a message saying that the login details are incorrect or that the MyAudi account is not verified and you have followed the above steps, you will need to ring Audi UK and ask them to have the German support team delete all MyAudi account data associated with your car from the server. You will then have to restart the process above including registering for MyAudi.
    1 1 0
  8. Re: MMI Define Primary User
    Dec 2012
    Frome, Somerset
    Thanks for replying
    I am fine up until step 4. In the MMI there is no such thing as Manage Key user, just doesn't give me the option. Can you check if you've got in and tell me what its labelled in the MMI and give me the full thread.
    Given you've got in does this now give you Vehicle Control in the MMI Connect App?
    Max
  9. Re: MMI Define Primary User
    Apr 2016
    6 Post(s)
    Quote Originally Posted by maxwide View Post
    Thanks for replying
    Max
    Yes, I now have full control in the Connect App. It's my wife's car, so I will have a look in the MMI menu when I can and report back.
    1 1 0
  10. Re: MMI Define Primary User
    Dec 2012
    Frome, Somerset
  1. Audi Connect User Management - Not in MMI?
    By pyrochris in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 29-11-2017, 07:35 PM
  2. Fuel pump primary circuit malfunction?
    By a3aud11 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-10-2014, 04:45 PM
  3. What causes primary or secondary engine failure on 2.0 tdi ?????????
    By roborod1969 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-08-2011, 09:51 PM
  4. MMi - One touch memory - Reset user profiles
    By robrover in forum A8 - S8 - V8
    Last Post: 23-01-2011, 11:23 PM
  5. MMI User Manual
    By MykeH in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-04-2008, 01:57 PM
