Thread: Correct battery for 1.9 130 sport pls
Results 1 to 8 of 8
  1. Correct battery for 1.9 130 sport pls
    May 2016
    Thurso
    Hi need to replace battery on my 2003 1.9 130 sport.
    I'm getting conflicting information on correct battery for it. It previously had a 72 Amp battery and I'm told it must be a 90Amp but it will not fit. So is 72 correct or might it be a higher ampage?
    Any advice highly appreciated
    Thank you.
  2. Re: Correct battery for 1.9 130 sport pls
    May 2012
    Glasgow
    My 2001 1.9 130 has an exide EB802.
    80ah. 700A(EN).
    Dimensions are-
    315mm X 175mm X 175mm
    Hope that Might help
  3. Re: Correct battery for 1.9 130 sport pls
    May 2016
    Thurso
    Thank you. My motor factor is adamant that from 2002 onwards it should be a 90amp but can't see why if it's exactly the same engine.
  4. Re: Correct battery for 1.9 130 sport pls
    May 2012
    Glasgow
    Could be to with other components?, not sure, maybe someone else will chip in.
  5. Re: Correct battery for 1.9 130 sport pls
    Apr 2010
    Solihull, England
    I bought a new battery for my 2005 1.9tdi 130 Final Edition earlier this year - I remember there being some confusion over what I needed, but this is what I went for and it fits perfectly and works perfectly!
    Duracell DA74 Advanced Car Battery Type 096 - 5 Year Guarantee
  6. Re: Correct battery for 1.9 130 sport pls
    May 2016
    Thurso
    Thanks a million for the support guys. Really appreciate it.
  7. Re: Correct battery for 1.9 130 sport pls
    May 2012
    Glasgow
    One wee note- the one Gareth lists is not as long as the one in my car so I'd def go with his recommendation as maybe the physical size of batteries was changed in later models and chances are the hold-down bracket on yours would only work with one size of battery. If in any doubt just measure it I guess
  8. Re: Correct battery for 1.9 130 sport pls
    May 2016
    Thurso
    Thanks mate I'm just realising this as the one I bought would not fit which is same length as yours. Thanks.
  1. Question Identify Correct Battery
    By klaus1013 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2015, 05:16 PM
  2. Is this the correct Battery for a 2002 A4 1.9 TDi 130 ?
    By buster2010 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2014, 06:19 PM
  3. Question Correct Battery for 2003 1.9TDI 130 SE BORA
    By Deeps in forum Bora - 1998 - 2005
    Last Post: 16-06-2013, 09:55 PM
  4. GT TDI 130 Newbie help pls!
    By GT TDI PD 130 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-09-2008, 11:38 AM
  5. 2002 S3 Battery???? PLS HELP!!!!
    By Eish3 in forum Audi A3 - Archive Topics
    Last Post: 19-08-2008, 03:32 PM
