Thread: battery coding and bem number requires
Results 1 to 10 of 13
  1. battery coding and bem number requires
    wondering if anyone who has just recently replaced their battery with an OEM battery can provide a serial number and a BEM number ?
    i purchased a Varta Silver F18 Battery , but it has no details that i can input into the battery coding , the spec is as follows 85 AH , CCA 800 A
    Im told that this was the battery for my A6 , as i was having problems with what i think was a defective battery that had deteriorated through age , that was a Bosch S4 010
    I have Ross-tech Hex-can vcds, and can get into the coding section but need numbers to input
    any help most welcome
    Thanks Greg
  2. Re: battery coding and bem number requires
    Jun 2008
    Simply change one number out of the ten which come after the manufacturer code. I changed from VAO0605080681 to VAO0605080680. It doesn't have any kind of logic to determine what manufacturer the battery is - it just wants to know it's been changed. Even if you didn't change anything, it would work it out for itself that the battery had changed from its improved charge / discharge characteristics. Code changing only speeds up the adaptation of the battery monitoring to the new battery.
  3. Re: battery coding and bem number requires
    Thanks for that
  4. Re: battery coding and bem number requires
    Dec 2015
    Southend, UK
    I enabled battery monitoring in the hidden menu but all this shows is a scale from 0 to 100% but no pointer. Does this suggest the last owner may have changed the battery without updating ? What can I do to enable a proper view of battery charge ?
  5. Re: battery coding and bem number requires
    are sure you have the most up to date software think by memory it's 5570, you can buy discs for around £20 on eBay ( mines were OK but I cannot guarantee if you go down this route ) after that it should show the battery state in increments on the display
    Greg
  6. Re: battery coding and bem number requires
    Mar 2013
    Lincolnshire
    Mines not 5570 (which is the latest) but I still have a segment battery gauge in 10% blocks from 0% to 100%
    A6 2008 57 Reg 2.7TDi SE Tiptronic Avant Quattro
  7. Re: battery coding and bem number requires
    Dec 2015
    Southend, UK
    Yep, MMI updated to 5570 before I even washed the car. The battery monitor just looks like a blank red scale
  8. Re: battery coding and bem number requires
    If it is a fully red scale then you are laughing it's 100% ,just leave the ignition on and the battery monitor on the screen and you will see it drop
  9. Re: battery coding and bem number requires
    Markaz there are guys more versed on here than e but I believe there was a software update within 5570 for the battery controller , it may be that
  10. Re: battery coding and bem number requires
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    1. Battery monitor is a pretty inaccurate measure of anything.
    2. Genuine software update discs are only 7/8 quid from Audi.
  1. Aftermarket battery coding
    By zafirovp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-01-2016, 01:32 PM
  2. New battery, is coding required?
    By gregpot2000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-01-2014, 11:02 PM
  3. Please Help Battery coding
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2013, 07:42 AM
  4. Battery Monitor Coding Question
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 04:45 PM
  5. A6 2006 BAttery Coding
    By snight123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-04-2011, 10:10 AM
