Thread: Q7 (4M) Coding
Page 6 of 71 FirstFirst ... 456781656 ... LastLast
Results 51 to 60 of 704
  1. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #51
    Sep 2016
    Western Pennsylvania, USA
    Seat Symmetry + Passenger Seat Control
    Description: For Q7 (4M) cars that have BOTH Driver and Passenger memory seats installed (with the buttons in the doors) you can make both the drivers seat and passenger seat "line up" so they are symmetrical. In addition, you can move the passenger seat using the seat movement buttons on the drivers seat. This change enables these features if you have ONLY Driver Memory Seat installed.
    Notes: Not been tested on Q7 4M cars that have neither driver or driver/passenger memory seats installed but it should work.
    Usage: Once coded, go into MMI, Car / Vehicle Settings / Seats. A new option for Passenger Seat will have appeared. There will be 2 options inside. One to line both front seats up together, and the other to move the passenger seat with the driver seat movement buttons.
    Risk: Medium
    Coding: Coming Soon....
    This worked for me on USA Q7 using OBDeleven as follows:
    In BOTH of these modules: 06/Seat Adj Pax Side and 36/Seat Adj Driver Side
    In Coding, set Passenger_seat_adjustment_by_driver_seat to Active. This enables the menu to control pax seat from driver seat controls.
    In Coding, set Seat_symmetry_movement to Active. This enables the menu to match pax seat position to driver seat position.
    My car DOES NOT have the memory buttons on the passenger side, and this still works.
  2. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #52
    Mar 2010
    37 Post(s)
    228 Post(s)
    Dear all
    Coding on main page has been updated:
    • Lock / Unlock Chirping
    • Disable Low Wind Noise Position on Sunroof
    Enjoy
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  3. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #53
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by RickOb View Post
    Thanks RickOb, I'll collate against the coding screenshots I have for this and post.
    Cheers!
  4. Re: Q7 (4M) Coding
    #54
    Sep 2016
    Thanks for the sunroof coding. Unfortunately, OBD11 does not seem to have the CA module accessed. Will be putting in a request on their forum.
  5. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #55
    Sep 2016
    Steering Wheel Heater:
    Module 16/Steering Column Electronics
    Adaptation: steering wheel heater
    Mine was already defaulted to 34 deg (USA Q7). I changed it to 38 deg. We'll see what happens.
  6. Re: Q7 (4M) Coding - Last Updated 22/9/2016
    #56
    Sep 2016
    Locking/Unlocking flashes and chirps:
    Both locking and unlocking flashes change worked for me.
    Locking double chirp worked for me.
    However, setting the unlock to single chirp does not result in any chirp at all. Neither does double chirp on unlock. Nada.
    USA Q7 March 2016 build.
  7. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #57
    Mar 2010
    37 Post(s)
    228 Post(s)
    Be careful above 36c. It's why I haven't posted it as it can cause damage. 34 is the global default
  8. Re: Q7 (4M) Coding - Last Updated 22/9/2016
    #58
    Mar 2010
    37 Post(s)
    228 Post(s)
    Can you do a coding and adaption map export for me?
  9. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #59
    Sep 2016
    In module 46/Comfort there are several codings for "range limitation X" where X is lock, rear, opening, panic. The first three are "active" in my car. I wonder if making them not active would increase the range of the key fob for some functions.
  10. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    #60
    Sep 2016
    Quote Originally Posted by andyhud007 View Post
    Thanks. I'll change mine back to 34 or 36.
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
