Thread: Q7 (4M) Coding
Page 58 of 70 FirstFirst ... 848565758596068 ... LastLast
Results 571 to 580 of 695
  1. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Jul 2016
    usa
    Anyone knows of the mkii Q have to ability to do this with coding ?
    VW Tiguan, MY2012 - auto rain closing activation - samodejno zapiranje stekel ob dežju - YouTube
    Apparantly the Q3 have this coding. Couldnt find anything similar in the Q7 coding
    Allow Rain Sensor to Close Sunroof & Windows - Audi Q3 Forum
    [09 - Cent. Elec.]
    [Coding - 07] -> [Long Coding Helper] -> [Byte 4]
    [Bit 5 - Comfort Operation Windows/Sunroof via Rain Sensor (0=nonrecurring/1=permanent)]
    => Check Box
    [Bit 6 - Comfort Operation Windows/Sunroof via Rain Sensor (Rain Closing) active]
    => Check Box
    Esc or Exit
    Transfer Coding
    Do It!
  2. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Mar 2010
    37 Post(s)
    228 Post(s)
    I've seen this somewhere. I think it's in the sunroof module. Check the long coding in there as a start.
    Ive not tried it personally.
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  3. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Jul 2019
    US
    I was able to figure out the wink and taillights in with DRLs if they haven't already been posted.
    Sent from my LM-G710 using Tapatalk
  4. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by Keebler21 View Post
    Don't think we got round to posting that so if your happy to share I'll put on the first post. Thankyou
    Andy
  5. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Jul 2019
    US
    Quote Originally Posted by andyhud007 View Post
    Andy
    For my 2019 US model.
    I went into central electronics (09), then coding (07)-long coding helper.
    It's under Byte 3, which should read 2B once you make the change.
    I checked bit 3 for "SI & DRL active"
    Then in the drop down under Bit 5-7 I selected the "20 DRL at indication config dimming".
    This appears to dim the DRL to 20% when you indicate instead of turning it off entirely. Also the taillights are always on now. There were a few other selections in that drop down that may keep the DRLs brighter but I didn't have time test those combinations.
  6. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Mar 2010
    37 Post(s)
    228 Post(s)
    Thanks Keebler21
    Its under Byte 2 for reference
    In the UK, we have "sl_at_drl,active" enabled from factory so when we indicator the DRL's just "dim" by default. I guess in the US its different.
    Our Bits 5-7 are set to "00 drl_at_indication_config,full_available". Ill see which combo keeps the taillights always on. Thats a good one to have.
    Appreciate you sharing this info with the community. Once I've worked out the other permutations I'll update the main page.
    Andy
    1 1 0
  7. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Oct 2019
    Earth
    23 Post(s)
    Does anyone know the coding for Lane Assist? I've followed this post, Repost: Coding for turning on Audi Active Lane Assist (all cars with pre sense) - AudiWorld Forums, but for module 44 I get Out of Bounds error.
  8. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by tweetyblu View Post
    Whats the part number of your Steering Unit (44)?
  9. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Oct 2019
    Earth
    23 Post(s)
    4M0 909 144 G
    The correct coding is byte 2 bit 0.
  10. Re: Q7 (4M) Coding - Last Updated 3rd March 2019
    Oct 2019
    London, Canada
    Hello everyone - new forum member here.
    Would anyone here possibly know the correct coding to disable the automatic rear wiper when Reverse gear is selected with the front wipers activated? The automatic rear wiper function can be a pain if the front wiper control is left in the "Auto" mode position (for example) and there's no need for a wipe of the rear window -- particularly for those times when it's not raining and the rear window is dry!
    As ref.. here's a link to a same-topic thread posted in the AudiWorld Q5 MKI (8R) forum back in 2016:
    Turn off automatic rear wiper when in reverse? - AudiWorld Forums
    As info I use the OBDeleven device to make coding changes to my Audi vehicle.
    Regards, Richard
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
