Thread: Q7 (4M) Coding
Page 55 of 71 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 704
  1. Re: Q7 (4M) Coding
    Apr 2010
    Surrey
    23 Post(s)
    Great work Andy, this is definitely a plus if you have adults/older kids and children in the back.
  2. Re: Q7 (4M) Coding
    Feb 2019
    Quote Originally Posted by andyhud007 View Post
    For SQ7 layout yep, this is correct. (this still doesnt allow the single centre SQ7 dial format to be enabled however if the car has over 100Km on the clock)
    I took delivery of my Q7 with more than 100km on the clock as it was put in service a few months back and had been driven by some execs, so can't change this but just more out of curiosity...
    If one were to mod this, could one mod it back and forth if the initial change was done prior to 100km?
  3. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by samps View Post
    You can mod it "back and forth" while the car is under 100Km, but as soon as it crosses that mark, then whatever the last setting was applied will then stick permanently.
    HTH
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  4. Re: Q7 (4M) Coding
    Feb 2019
    Hey Andy et al.,
    Wondering about two that I tried and looked around (based on 2014 Q5 coding), but can’t seem to figure out.
    1. Disable winking of DRL on turn signal.
    2. Start in ADS mode from shutdown, i.e. if in dynamic mode when starting car transmission will be in ‘S’. If in auto will start in ‘D’.
  5. Re: Q7 (4M) Coding
    Feb 2019
    HTH
    Andy
    Yes totally. Was genuinely curious about this. Thank you.
  6. Re: Q7 (4M) Coding
    Mar 2019
    Copenhagen, Denmark
    Is it possible to change the ambient light colours for the different driving modes so that when you choose interior lighting based on driving mode it will have other colours than the default ones?
    Would be nice to have:
    lift / offroad = yellow
    allroad = pink
    efficiency = green
    comfort = white
    auto = blue
    dynamic = red
  7. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by sykulski View Post
    allroad = pink
    efficiency = green
    comfort = white
    auto = blue
    dynamic = red
    Not found a way to do this yet....
  8. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Hey Andy et al.,
    I think DRL Winking can be done via ODBeleven "app" which means its just a basic coding change somewhere in Module 09 if I recall. I know I havent posted anything on first page about this, but I'm sure its in this thread somewhere.
    Not sure on number 2, sorry.
  9. Re: Q7 (4M) Coding
    New Forest
    80 Post(s)
    Would this require different colour LEDs to be fitted? If so, it might be that factory-fit is only a single-colour strip unless specified.
    Sent from my SM-G965F using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  10. Re: Q7 (4M) Coding
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by ragebe View Post
    Good question actually. Question: If you dont have full multi-colour Ambient lighting does changing the drive select modes change the standard "white" colour to different ones as you flick through the different Drive Select modes (auto/comfort/dynamic etc)? I assume not, but thought I'd ask because if it did there could be a route there that means its just datasets and coding.
    Otherwise, yes, you need different LED modules in trim strips that light up to support the full colour spectrum (and that is also extra wires).
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
