Thread: Q7 (4M) Coding
Page 26 of 71 FirstFirst ... 16242526272836 ... LastLast
Results 251 to 260 of 704
  1. Re: Q7 (4M) Coding - Last Updated 22/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Nah no beans either sadly... It's hidden away somewhere
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  2. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Nov 2016
    Tampa, USA
    11 Post(s)
    I've read the OP which i assume is a collaboration of all the modifications in the thread. Has anyone come out with coding to enable VIM? I know there are apps one can pay for that will do it for you.
    Thanks!
  3. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by boman5000 View Post
    I've read the OP which i assume is a collaboration of all the modifications in the thread. Has anyone come off with coding to enable VIM? I know there are apps one can pay for that will do it for you.
    Thanks!
    Hi Boman
    You can't "Code" VIM like you could in older Audi's with a serial number generator. Its a direct write into the EEPROM. The cheapest way to enable VIM is with an ODBEleven device and buy the option for 10 Euros. This is what I did and works.
    VCP also does it but is more expensive.
    It can't be done in VCDS. Its impossible.
    HTH
    Andy
  4. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Nov 2016
    Tampa, USA
    11 Post(s)
    Quote Originally Posted by andyhud007 View Post
    Hi Boman
    HTH
    Andy
    Thanks for the info. I've got an ODBEleven so I'll go that route.
  5. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Nov 2016
    Tampa, USA
    11 Post(s)
    Hi Boman
    HTH
    Andy
    Hi Andy, once it's enabled through ODBEleven, is it permanently set? I've read some conflicting info. One thing I read was it cost 100 credits to use it each time. Another was that it didn't cost you again but you have to enable it through the ODBEleven each time you want to use it.
  6. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    No mate, thats all rubbish. Once its set , its set. Only if Audi re-applied the firmware to your MMI unit in the glove box (which would only occur if they stuck an SD card update in your MMI unit) would it potentially reset, but even then it might not.
    Otherwise no. Its permanent.
  7. Re: Q7 (4M) Coding - Last Updated 6/8/2016
    Nov 2016
    Tampa, USA
    11 Post(s)
    Great news, thanks for your help.
  8. Re: Q7 (4M) Coding - Last Updated 22/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Now I saw something the other day about this, problem is I cant remember where I saw it, but I think its possible!
  9. Re: Q7 (4M) Coding - Last Updated 22/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by easyeieio View Post
    Did you have any luck with this ?
    Dumb post. Sorry. I meant I found something about Google Street View working while driving.
  10. Re: Q7 (4M) Coding - Last Updated 22/11/2016
    Jun 2011
    london, uk
    7 Post(s)
    ok people
    I've found what to change to get the VC to display SQ7 dials
    In module 17 go into long coding
    Then change vehicle variant to "derivative 2"
    Apply changes
    Come out of long coding
    Choose reset
    Then hard reset
    And hey presto!
    Have fun
    Wolek
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
