Thread: Q7 (4M) Coding
Page 20 of 71 FirstFirst ... 1018192021223070 ... LastLast
Results 191 to 200 of 704
  1. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by srbsq7 View Post
    Thanks Joerez! Very handy now the weather is starting to get colder (especially as no aux heater this year!)
    I just enabled this and it works immediately without having to switch of the ignition etc.
    One thing I noticed is, you can lock the car with the fob or touching the handle (if you have advanced key), however you need to use the unlock button on the key - touching the handle or boot doesn't unlock. I'm happy with this and probably a good safety feature.
    Thanks again
    Thanks for trying it SrbSq7! Great feedback!
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  2. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Sep 2016
    Western Pennsylvania, USA
    Thanks again
    I noticed that after locking with the engine running, the boot is not locked UNLESS you set "Disable tailgate handle" to ON in the MMI central locking section. (US 2017 Q7 Prestige)
  3. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Apr 2016
    Stansted
    169 Post(s)
    Quote Originally Posted by RickOb View Post
    Hi Rick,
    I just checked mine and "Disable tailgate handle" isn't checked but the boot is also locked. If I press the boot button on the key, the boot pops open slightly, but I need to touch the handle for it to open completely. At this point, all the doors remained locked and required the unlock button to be pressed on the key. Shutting the boot locked it again.
  4. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Sep 2016
    Hi Rick,
    There seem to be three bits in Module 46 coding in OBDeleven that "may" affect this:
    central_locking_sys_lock_unlock_at_eng_running
    auto_lock_not_at_mmi (4th to last entry)
    auto_lock & auto_unlock
    (Mine are currently set to not active, not active and active respectively)
    Not sure if some combo of these may be the reason, or the fact that I have the Viper remote start wired in and that is affecting it.
  5. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Oct 2016
    U.S.
    I just checked mine also and "Disable tailgate handle" isn't checked but the boot is locked, it will only unlock when FOB unlock is pressed. I have a Prestige Model
    Some one from another forum who has a remote start was asking about the range on the Audi FOB isn't good, I posted this in regards to range limitations of the Audi FOB
    This is the VCDS coding for Removing Key FOB Range Limitation.
    Address 46: Central Conv.
    Byte 28
    UnCheck Bit 1 Range Limitation Lock
    UnCheck Bit 2 Range Limitation Rear?
    UnCheck Bit 3 Range Limitation Opening
    UnCheck Bit 4 Range Limitation Panic
    I just UnChecked all 4, but never did testing to see if actual range is gained. If someone can do a unlock / lock test to see what distance it stops working then do this coding and see if range is gained that would nice to confirm.
  6. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Hey JoeRez
    Yep, I saw those channels too. but not checked to see what those values mean in terms of true distance (for example, does it reflect Centimetres/Inches etc?
    I know that boot close using keyfob you need to be close to car by default, but to open boot from keyfob you can be further away
    Needs some investigation....
    I'll see if I can do this today on mine...
  7. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Oct 2016
    U.S.
    This is regarding steering Wheel Heat
    The module is 16 Steering wheel in VCDS or 16 Steering Column Electronics in OBDeleven and this is just an Adaption, no coding necessary
    My default value from the Factory was set at 34 degrees and the max value you can change to is 45 degrees. andyhud007 said after speaking with Audi Don't go over 38 degrees may cause damage.
  8. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Hey Joe,
    I think this was discussed before and after speaking to Audi on it they said dont set it over 36/38c I recall for potential damage to the steering wheel. Its why I didnt post the coding in the end but good luck!
  9. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Sep 2016
    Mine was factory set at 34. After Andy's comment about possible damage, I decided to leave it as is until it got cold enough to want to use it. Now that I've used it a few times on cold mornings, I'm finding that 34 is just fine. It's gets nice and warm. Not sure I'd want it any higher.
  10. Re: Q7 (4M) Coding
    Oct 2016
    U.S.
    Thank you Andy and Rick, I updated my post with your warning. I was unaware, going to lower to 40 and test.
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
