Thread: Q7 (4M) Coding
Page 16 of 71 FirstFirst ... 614151617182666 ... LastLast
Results 151 to 160 of 704
  1. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Apr 2016
    Stansted
    169 Post(s)
    Thanks for your videos Andy. Mind made up on the single chirp!
    Former Q7 owner
  2. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    New Forest
    80 Post(s)
    Hmm, rather worryingly, Module 46 no longer responds and I can't open it.
    Sent from my STV100-4 using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  3. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Apr 2016
    Stansted
    169 Post(s)
    Thanks again Andy. Enabled the single chirp on lock & unlock so only needed to do these 3 steps from your instructions:
    1) Enable the "Tone when Locking" option in the MMI by checking byte 4 / bit 6 - great that you can just turn off in the MMI
    2) Enable adaptation "beep_at_opening"
    3) Set adaptation "beeptime_opening_central_locking" to "single_beep"
    This was done with OBDeleven.
  4. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by ragebe View Post
    You using ODBEleven? or VCDS + Hex-Net?
    Leave car for 15 minutes to allow the can-bus to silence and try again.
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  5. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by srbsq7 View Post
    Great stuff SrbSq7... glad its working for you!
  6. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    New Forest
    80 Post(s)
    Quote Originally Posted by andyhud007 View Post
    VCDS + Hex-net Rls 16.8.3
    I've tried leaving it but still can't access the controller
  7. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    New Forest
    80 Post(s)
    Ran a full scan this morning and Module 46 doesn't appear in that either. Anyway of addressing the module direct? i.e. do I just type 46 into the box and press go as per this page? http://www.ross-tech.com/vcds/tour/scm_screen.php
    Thursday,03,November,2016,09:24:05:41500
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 16.8.3.1 (x64)
    Data version: 20161010 DS267.0
    Ross-Tech: Home
    VIN: xxxxxxxxxxxxxxxxxxxxxxx License Plate: xxxxxxxx
    Mileage: 10241.7 Repair Order:
    Chassis Type 4M (4M2)
    Scan: 01 02 03 06 08 09 13 15 16 17 19 28 2B 36 42 44 47 52 5F 6C
    6D 81 82 8B A5 AC BB BC
    VIN: xxxxxxxxxxxxxxxxxxxxxxxx
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: Malfunction 0010
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: Malfunction 0010
    81-Gear Shift -- Status: OK 0000
    82-Heads Up Display -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    AC-Reductant Control -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
  8. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    New Forest
    80 Post(s)
    Typing 46 doesn't work. Just can't access that controller. Remote lock/unlock and opening/closing of windows and sunroof all work still.
  9. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    Mar 2010
    37 Post(s)
    228 Post(s)
    Hmm, very strange. have you flashed your Hex-Net dongle with the latest firmware from Ross-Tech?
    You have a lot of malfunctions too.. that isnt right. Are you sure you have pressed ignition button once so electrics are on before doing the Auto Scan??
  10. Re: Q7 (4M) Coding - Last Updated 02/11/2016
    New Forest
    80 Post(s)
    Yes, did that this morning. Downloaded 16.8.3 yesterday evening.
    VCDS knows that Module 46 but it can't initiate contact.
  1. Help with some coding please
    By troytroy in forum VCDS - General Questions
    Last Post: 07-02-2020, 12:42 PM
  2. C6 coding
    By simonrk57 in forum VCDS - General Questions
    Last Post: 18-03-2013, 08:10 PM
  3. coding - how to get this!
    By Touran200409021 in forum VCDS - Help Requests
    Last Post: 12-09-2011, 10:47 PM
  4. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  5. Help with coding please.
    By benjie in forum VCDS - Help Requests
    Last Post: 27-08-2010, 02:21 AM
