Thread: Key Signal, immobiliser problems
  1. Key Signal, immobiliser problems
    Aug 2010
    kigsbridge, devon
    Hi all, been to help a mate with a 98 A4 tdi with immobiliser problems. Starts and stops straight away. After a vcds scan, instrument cluster - 01176 key signal too low.
    Engine - 17978 start blocked by immobiliser.
    I have done a reboot by disconnecting battery.
    Tried both keys
    Checked connection on back of instrument cluster.
    Ross tech wiki suggests it's the read ring around the ignition, is this a common problem? Going to have another look tomorrow when it's not raining.
    Has anyone experienced this before?
    You don't know how it works until you take it apart!
  2. Re: Key Signal, immobiliser problems
    Aug 2010
    kigsbridge, devon
    Got in to the reader coil this evening and checked wiring right through to the dash, all intact.
    Key signal fault has now gone but 'engine start blocked by immobilizer' is reoccurring. Im at a loss now of where to look next........
  3. Re: Key Signal, immobiliser problems
    Dec 2011
    Southsea, United Kingdom
    Buy an immobiliser removal tool/dongle from ebay/China? 5mins and the immobiliser will be disabled, if you really want one, fit a 3rd party one. Done. Easy.
    Sent from my SM-G900F using Tapatalk
  4. Re: Key Signal, immobiliser problems
    Dec 2011
    It could also be the key simply needs to sync, after I'm guessing so many attempts to start the car, the codes will have rolled on - but - this is a guess
  1. low key signal
    By tazmania_1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-03-2011, 12:49 AM
  2. 01176 key signal too low
    By pops20vq in forum Golf MK4 - 1999 - 2004
    Last Post: 04-08-2008, 07:22 PM
  3. Please Help immobiliser Problems - immobiliser bypass?
    By MC_BLADE in forum Audi A3 - Archive Topics
    Last Post: 31-07-2008, 07:35 PM
  4. new v5 key, but no immobiliser code
    By leemeg99 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2008, 03:53 PM
  5. key fob/ central locking/immobiliser problems
    By adamoliver in forum Polo - Derby - Lupo - Fox
    Last Post: 04-12-2007, 08:56 PM
