Thread: Oil pressure light A4
  1. Oil pressure light A4
    Sep 2007
    Hi I have an Audi a4 2005 2.0tdi the oil pressure light has come on, was wondering if an oil and filter change would resolve this? oil has not been changed for a while
  2. Re: Oil pressure light A4
    Pembrokeshire
    22 Post(s)
    more than likely it wont help. search 2.0 tdi oil pump problems.
  3. Re: Oil pressure light A4
    May 2012
    Everywhere
    308 Post(s)
    Another member of the 77mm Club .
  4. Re: Oil pressure light A4
    Sep 2007
    Hi just had my car in to local garage to get checked, been told everything pointing to oil pump looking at £2000 - £3000 to get fixed does that sound about right or should I try and get 2nd opinion before getting rid of car?
  5. Re: Oil pressure light A4
    May 2012
    Everywhere
    308 Post(s)
    Nope , thats for a complete oil pump twin balancer shaft module , you only need 1 remanufactured modified balancer shaft and longer harder 100mm hex key £215 + 3 - 5 hrs labour .
  6. Re: Oil pressure light A4
    chester
    17 Post(s)
    You need to check if you've got a chain driven or gear driven,if its chain driven chances are the chain, teeth, and tensioner are in bad shape so the garage are giving you a worse case senario.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  7. Re: Oil pressure light A4
    May 2012
    Everywhere
    308 Post(s)
    Good point it could of been the double trouble of the chain tensioner breaking and the slack chain whipping the teeth off .
    Did garage say it was chain or gear driven ?
  8. Re: Oil pressure light A4
    chester
    17 Post(s)
    2005 model its most probably a chain driven,unless you've heard severe rattling at the front fingers crossed it maybe OK,get a quote for the upgraded balance shaft,problem is until you start stripping things down you just don't know the final bill.
  1. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  2. Oil Pressure Light on and oil temp not rising 02 AWX 1.9tdi
    By tone35 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2012, 10:10 AM
  3. audi low oil pressure light,check engine light
    By redviper131 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2010, 06:51 PM
  4. Please Help Oil Pressure/Red Oil Light
    By misterme23 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:07 PM
  5. Question oil pressure light
    By bsharbonda in forum 80 - 90
    Last Post: 26-05-2008, 01:35 PM
