Thread: Altering front windscreen washer jets
Results 1 to 10 of 11
  1. Altering front windscreen washer jets
    Aug 2015
    Maidstone, England
    Can anyone suggest a good method of adjusting one of the nozzles for the screen washer jets please?
    As most of you know they are located on the underside of the rope edge of the bonnet lid and not the easiest to get to.
    At the moment one of them is spraying the middle of the road rather than my windscreen.
  2. Re: Altering front windscreen washer jets
    Mar 2016
    Leeds UK
    Hi pal,
    You will have to open your bonnet and remove the washer jet from the bonnet.
    It is simple to do and will prise off with a flat head screw driver.
    Once removed there is a small torx screw which you turn to adjust.
    Be careful and make sure you use the correct screw driver as they round off pretty easy as the screw is soft plastic.
  3. Re: Altering front windscreen washer jets
    Aug 2015
    Maidstone, England
    Sounds like fun. I'll have a proper look tonight when I get home.
  4. Re: Altering front windscreen washer jets
    Apr 2011
    basingstoke,england
    12 Post(s)
    I just stick a pin in the hole and move it round, a bit hit and miss and very small movements make for big adjustments but has always worked for me.....perhaps I'm missing something!
    Sent from my GT-I9505 using Tapatalk
    2016 A6 Avant 2.0 tdi Quattro Black Edition
    2013 A6 Avant 2.0 tdi Black Edition ​gone
    2010 A6 Avant 2.0 TDI Le Mans. gone.
  5. Re: Altering front windscreen washer jets
    Aug 2015
    Maidstone, England
    Yeah that's the normal way of doing it if they are on top of the bonnet lid on most cars, but as it located under the bonnet it is much harder to get to to, least adjust with a pin because the edge of the bonnet lid reduces access, as does the wiper arm.
  6. Re: Altering front windscreen washer jets
    Nov 2014
    Aberdeenshire
    I ve always used a pin.
    Sent from my SM-G900F using Tapatalk
  7. Re: Altering front windscreen washer jets
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    I did mine last week and used a medium sized safety pin, bent open a bit so I had the reach, took about 10 mins to have them all set where I wanted them
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  8. Re: Altering front windscreen washer jets
    Stratford upon Avon UK
    36 Post(s)
    Quote Originally Posted by sentiMENTL View Post
    Might be easier if you drop into the MMI and put the wiper blades in "servicing mode" so they are parked up on the windscreen rather than in their bunker....
    A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
    1 2 0
  9. Re: Altering front windscreen washer jets
    Aug 2015
    Woking
    Quote Originally Posted by ukgroucho View Post
    Clever !
  10. Re: Altering front windscreen washer jets
    Jun 2011
    Drogheda Ireland
    Or when you turn off the ignition press the wiper stalk down once to activate the service position
  1. Question Windscreen washer jets
    By StephenM in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 29-05-2016, 09:03 PM
  2. Windscreen washer jets
    By invisiblekid75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-02-2014, 02:23 PM
  3. Windscreen Washer Jets...
    By srisport in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 23-05-2012, 03:08 AM
  4. Question Windscreen Washer Jets
    By mark27 in forum Bora - 1998 - 2005
    Last Post: 10-11-2010, 09:32 AM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
