Thread: Audi 80 Manual Roof
  1. Audi 80 Manual Roof
    Jun 2016
    worthing
    Hi guys, I really hope someone can help. I have A 1996 Audi cabriolet with a manual roof.
    So the procedure to open the roof is as follows
    Key in the ignition and turn on
    switch by the hand brake drops all the windows
    pull down and twist the handle by the rear view mirror and the roof releases.
    lift up the rear of roof and press the switch inside drivers door to release bit where the roof folds into
    fold down roof, job done
    However today this is not working, this is what is happening now
    Key in ignition and turn on
    The switch by the handbrake does not drop the windows
    When you pull down and twist the handle it only turns a tiny bit and the roof is still locked in place.
    I really hope someone can understand what i am saying i have no idea what to do.
    Thank you so much for reading Xx
  2. Re: Audi 80 Manual Roof
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    How long since you last opened the roof.
    When you turn the handle, this should operate the windows automatically.
    If your twist handle mechanism has not broken or seized there are many things to inspect.
    Handbrake switch must work, otherwise the car thinks it is moving and will not allow roof to open
    Boot lock must be working correctly, otherwise car may think the boot is open and will not allow roof to open.
    Have a poke around at the fuse box and check window operation fuse.
    Check switch is not faulty.
    The most common cause for faulty roof operation is that the cable in the boot hinge area on both sides have been damaged, you may look at them and think they are ok but they may be damaged internally, been there myself
    These issues are not specific to just the auto hoods but will upset manual roof aswell.
    Have a poke about and come back to us
    Stuart
  1. 1993 Audi Cabriolet - Manual Roof - 3 Hands?
    By snoopstah in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-01-2015, 02:26 PM
  2. Manual roof issues on a '98 cabbie
    By wacky77 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-08-2011, 10:18 AM
  3. Question 1990 Audi Manual Sun Roof
    By crismcoffin in forum New Member Introductions
    Last Post: 01-10-2009, 12:16 AM
  4. Manual to electric roof
    By galione in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-07-2009, 05:04 PM
  5. manual roof problem
    By tazdevilandy in forum Chat - Anything with wheels
    Last Post: 23-09-2008, 09:48 AM
