Thread: Fluctuating idle when cold
Hybrid View
  1. Fluctuating idle when cold
    Jun 2016
    Rutland, UK
    Apologies for my non technical description on this, when I start my diesel (2.0 bluemotion) up from cold I get a lumpy idle, e.g. it doesn't feel like the engine is ticking over as smooth as it should. Rev gauge seem to fluctuate rather than a smooth start.
    I blip the accelerator and it settles down and is fine after a couple of seconds. I don't get this once warm. I was suspecting battery, but I'm not so sure now.
    Any ideas?
  2. Re: Fluctuating idle when cold
    Jul 2007
    glasgow
    35 Post(s)
    Replace Coolant Temp Sender Unit with a genuine one
    Take it your waiting for glow plugs to go out, wait 2 seconds & then start ?? The 2 seconds allows the glow plugs to work their magic as they still heat up after the light goes out
  3. Re: Fluctuating idle when cold
    Jun 2016
    Rutland, UK
    What's the reasoning behind swapping out the coolant temp sender unit?
    Yep, I'm waiting for glow plugs to go out. The light goes out really quick, and I've been leaving for around 20 seconds before starting up, which does seem to help.
    I've also put some RedEx to help clean the injectors, etc.. So a combination of these things seems to be reducing the effects.
  4. Re: Fluctuating idle when cold
    134 Post(s)
    2007 Post(s)
    Get a code read done first, it's not had this stupid recall done has it?
  5. Re: Fluctuating idle when cold
    Jun 2016
    Rutland, UK
    I'm trying to find someone locally that can help out with the VCDS scan.
    No, hasn't been called in, for "the fix".
    Interestingly the idle issues have calmed down, but when I pull away the revs fluctuate up/down. A couple of seconds of driving and it's fine and calms down.
  1. Engine rpm fluctuating/jumping at idle
    By A4flyer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2013, 08:04 PM
  2. 94 1.4 Golf fluctuating idle and poor starting
    By manc in forum Golf MK3 - 1993 - 1999
    Last Post: 26-06-2012, 11:58 PM
  3. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  4. B4 2.0E ABK idle speed fluctuating
    By ervin_slo in forum 80 - 90
    Last Post: 26-01-2008, 10:33 PM
  5. cold idle
    By polo1.4cl in forum Polo - Derby - Lupo - Fox
    Last Post: 07-12-2007, 09:09 PM
