Thread: Im Stumped! Any Ideas?
Results 1 to 8 of 8
  1. Im Stumped! Any Ideas?
    Jun 2016
    Wichita, Ks
    I recently aquired an audi a42.0t with 120,000 miles. I was told it was misfiring and just needed a camshaft position sensor. Check engine light and EPC light are on. I ran a scan and have these error codes:
    p2014 intake manifold runner sensor
    p0190 fuel rail pressure sensor
    p0118 engine coolant temp sensor
    p0113 intake air temp sensor
    p0343 cps a circuit high input b1
    I did just put a new camshaft position sensor, no change. I read a forum where a guy had same error codes and it was a bad ground from the ECU. Not sure if ive checked all possible grounds. Any direction or advice would be much appreciated. Thank You!
  2. Re: Im Stumped! Any Ideas?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    If you can, have you tried clearing your fault codes and driving the car and re-checking the codes to eliminate spurious errors? A list of faults can lead you in the wrong direction.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Im Stumped! Any Ideas?
    Jun 2016
    Wichita, Ks
    Maybe should have mentioned how it runs. It fires up fine. usually idles ok, but when you give it gas rev in N, or in gear. It hesitates, shakes, misfires( whatever you wanna call it) and is hard to accelerate. Once up to speed, runs ok. I think I had narrowed it down from much research.
    Symptoms seem similar to:
    -HPFP leak ( which it may had, long story short, pump was held by one snug bolt, one stripped, and no third bolt..waiting for stud kit and new banjo bolt)
    -low pressure fuel sensor failure
    -clogged fuel filter( just ordered one)
    -bad ground?
    -worn cam lobe( ive checked it, No visible wear, can see even chamfer all was round apex)
    Am I on the right track?
  4. Re: Im Stumped! Any Ideas?
    Jun 2016
    Wichita, Ks
    Thanks Alan02 for your reply, I have erased codes. No change
  5. Re: Im Stumped! Any Ideas?
    Jul 2007
    glasgow
    35 Post(s)
    yeah change BOTH fuel & air filters
    Then take the car onto a straight piece of road, keep car in 2nd gear and boot it until the revs are just under the red for a good couple of hundred yards, look in mirror & confirm all the crap has been blasted out of car
    clear faults and then tell us whats happening
  6. Re: Im Stumped! Any Ideas?
    Oct 2016
    Houston
    @ bfunke, Hi! was wondering if you ever found what was wrong with your car? I have that same issue with same codes. Would appreciate your response. Thanks
  7. Re: Im Stumped! Any Ideas?
    May 2018
    Michigan
    07 a4 but 2.0t, had thermostat replaced, barely runs now, p0190 code, replaced fuel rail pressure sensor, cleared codes, no change and p0190 returned... Suggestions please?
  8. Re: Im Stumped! Any Ideas?
    Jun 2020
    San Marcos, CA, USA
    Bengar, sorry to dig up an old thread, but I’m having the same issue that both of you have. How did you fix?
  1. Please Help Water leak thats got me stumped
    By craig-v5-20v in forum Toledo
    Last Post: 26-10-2014, 09:21 PM
  2. Stumped newbie. Abs fault
    By wiggy7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-09-2013, 08:27 PM
  3. This ones got me stumped
    By Eddie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-08-2008, 10:02 PM
  4. This has stumped me..
    By hagis in forum Chat - Anything with wheels
    Last Post: 06-04-2008, 09:55 AM
  5. Sharan Starting problem...Stumped!!
    By kevdsn in forum Touran - Sharan - Caravelle
    Last Post: 08-09-2007, 09:44 PM
