Thread: Audi Q7 2009 MMI Display + Airbag light
  1. Audi Q7 2009 MMI Display + Airbag light
    Aug 2008
    Q7 2009 s-line
    My MMI display has gone black, I did try to replace the screen and the controls that did not make a difference, Music/CD/Btooth/Phone all work from controls and instrument display. It is just that the screen wont work, now that I replaced the screen what else should I look at.
    On a second note, when I replaced the screen the Airbag light came on , I am sure I did plug in all the plugs that I removed and I do not think they are Airbag related, I never noticed the Airbag light before and I am pretty detailed. Any connection ?
    Regards
  2. Re: Audi Q7 2009 MMI Display + Airbag light
    Jun 2014
    Monterrey, Mexico
    I once had a black screen at the MMI and all I did was to pull out every fuse (as I didn't know which one was for MMI) and put in again.
    Also there is a reset sequence which I don't remember quite well (pushing one of the MMI controls, maybe volume, for some seconds and every went reset).
    Now that you have the airbag light, you should think you making a VCDS scan before you continue buying stuff.
  1. Q7 2009 MMI Display issue
    By alinux in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 26-02-2016, 06:42 PM
  2. Audi A4 2009 2g MMI DISPLAY BRIGHTNESS DIM
    By kevsa in forum In Car Entertainment
    Last Post: 22-10-2015, 05:05 PM
  3. Audi A6 C6 mmi display not working
    By Roland Rigo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-09-2014, 09:24 AM
  4. Audi a4 b8 mmi monochrome display?
    By Gunnark100 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-10-2012, 12:28 PM
  5. Audi a6 2009 avant mmi ??'s
    By V6mxy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-03-2012, 02:16 PM
