Thread: halogen to led conversion
  1. halogen to led conversion
    Mar 2009
    hi guys,
    i have a audi 2013 a6 saloon se i have halogen lights fitted i am looking to upgrade the rear lights to sline i have been told i need a wiring harness. i have been quoted £200
    for the wiring and the coding dongle. do i require the coding dongle as i have access to vcds. and can i not make the loom.any help much appreciated.
    cheers
    joe
  2. Re: halogen to led conversion
    Dec 2005
    hi
    I was thinking about the same but it is too expensive in total. You need to change head lights, wiring, coding, washers(all xenons need to have washers to pass MOT) and last thing you need to change is self levelling to be fully compliant.
    Regards
  3. Re: halogen to led conversion
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by noogman View Post
    hi
    Regards
    The rule about headlight washers relates to the brightness not simply that it is Xenon. Following the facelift Audi has fitted Xenon as standard to the SE spec yet does not include washers as standard (as it did previously with the Xenon option). Apperently the lumen output of the FL lamp is below the threshold requiring washers as standard. Not sure if the pre-FL unit was brighter or simply that washers were included for marketing reasons
  4. Re: halogen to led conversion
    Jan 2016
    uk
    Hi Joe
    I am looking to do retrofit on my SE and can't seem to find a vendor/provider for wiring harness and dongle. Who did you get the quote from?
    Many thanks
  1. A6 C7 halogen to led retrofit
    By joeblogs in forum Retrofits
    Last Post: 11-06-2016, 07:46 PM
  2. Halogen to xenon conversion
    By jmckeown112 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2015, 12:39 PM
  3. Halogen DRL to LED
    By djkprojects in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-05-2014, 08:36 PM
  4. Halogen to HID Conversion
    By doberman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-02-2014, 04:38 PM
  5. conversion to Xenon HID Lights from Halogen
    By Pireeeh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-12-2011, 07:35 PM
