Thread: VW MK4 GTi Coolant sensor
Results 1 to 8 of 8
  1. VW MK4 GTi Coolant sensor
    Hello,
    Just recently registered here and am hoping someone can help me.
    I imported a mk4 gti from japan and when it came in the engine managent light was one. I brought it to get it checked and the mechanic told me it had been chipped and when he resets the lamp it will come back on after a few moments post start up. Just wondering if this is normal for a chipped car to cause the management light to stay on. Also recently the coolant warning alarm keeps coming on when i start up from cold. I checked the coolant and there is plenty there. Once it warm and i restrt the engine and the error will not come back on.
    Gerard
  2. Re: VW MK4 GTi Coolant sensor
    135 Post(s)
    2036 Post(s)
    No it isn't normal but there would have been a fault code stored so what was it. What year is the car and what is the engine code or failing that, PM me your chassis number (wvwzzz1Jz _ _ _ _ _ _ _ _) and I will tell you. No hang on you can't PM at one post. If you want to send it to me by email, I will PM you my email address.
  3. Re: VW MK4 GTi Coolant sensor
    Cheers that would be great.
    Dont have the number jet but ill get it soon. Its a 03 and when he plugged it in one of the errors was " max turbo pressure reached".
    It drives perfectly apart from when it cold it stutters a little untill warm...
    thanks
    gerard
  4. Re: VW MK4 GTi Coolant sensor
    135 Post(s)
    2036 Post(s)
    I had that one before many times and recently on one programed by some numpty with a lap top but that one toasted the engine before I got my hands on it. A new engine and an APR remap put it right. This sort of thing always happens when there is a new fad for opportunists to come along and ride the band wagon and people like us pick up the bits afterwards, literally!
  5. Re: VW MK4 GTi Coolant sensor
    So what do ya reckon ..
    Maybe get that chip out of there before it toasts mine too.
    How much did that set you back
  6. Re: VW MK4 GTi Coolant sensor
    135 Post(s)
    2036 Post(s)
    I didn't cost me, I was fixing it. It cost the owner literally thousands.
  7. Re: VW MK4 GTi Coolant sensor
    Doesn't sound good at all.
    Any ideas on the coolant warning coming on when i start it from cold.
    Also might that have anything to do it stuttering when cold also
    Thanks again
  8. Re: VW MK4 GTi Coolant sensor
    135 Post(s)
    2036 Post(s)
    I presume you mean the coolant level light? That is the level and nothing to do with temp. You need to get this car to someone who can help you, it sounds like the people you have consulted so far have been a little vague.
  1. coolant temp sensor in APT 1.8 20v
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2007, 02:23 PM
  2. mk3 coolant temp sensor
    By pazur in forum Vento - 1994 - 1998
    Last Post: 05-08-2007, 05:53 PM
  3. Coolant sensor info pls !
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 21-07-2007, 11:47 AM
  4. Replacing Coolant Temp Sensor in a Mk4 AGU 1.8T
    By Si_1.8T in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2007, 07:48 PM
  5. Coolant Temperature Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:25 AM
