Hi Folks,
I need some help and guidance on what to do next on my car ... Basically the
power steering radiator had a leak during the winter months which I got replaced
and its only now I've realised the garage must had remove the AC radiator at the same time as there wasn't any gas in it.
I have filled up the refrigerant but now the AC only blows out warmish air... below is my scan and I have noticed I have fault with the 18 AUX heater but no idea if both
are related..
Also are there any output tests I can do on the 08 Module to determine where my fault lies ? Really scratching my head on what to do next ...
K Regards..
Wednesday,01,June,2016,12:00:41:42343
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: WAUZZZ4 License Plate:
Mileage: 127640km-79311mi Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 47 4F 52 55 56
5F 62 6C 6D 6F 72 76
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
3D-Special Function -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (J623-CJGA) Labels: 059-907-401-V2.clb
Part No SW: 4L1 910 401 H HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L1910401H 001008
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 285FB4CA53567C7E16-807C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 AE HW: 0C8 927 750 AE
Component: AL1000 AISIN 001 1783
Serial number:
Coding: 001578
Shop #: WSC 15019 002 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_AU56.rod
VCID: 6FED9FD6B6386B4697-803A
Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200689
VCID: 346750BA579E089EAA-8060
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901642853
Coding: 0000211
VCID: 2541BDFEEC4461162D-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AE
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000030161247
Coding: 01009416
VCID: 2541BDFE2C4461162D-8070
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AD HW: 4F0 907 279 D
Component: ILM Fahrer H28 0360
Revision: 00000000 Serial number: 4F0907279
Coding: 0033121
VCID: 6BD58BC64A209766BB-803E
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D070GP$
Coding: 0014129
VCID: 2E5342D2B9B2224EDC-807A
Subsystem 1 - Serial number: 6332QSME0E6E053CT
Subsystem 2 - Serial number: 6342QSME286A3F22O
Subsystem 3 - Serial number: 6352QSME2D6E223EX
Subsystem 4 - Serial number: 6362QSME126E412CK
Subsystem 5 - Serial number: 63734SME7C505620
Subsystem 6 - Serial number: 63834SME7C69440CD
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026102050411
Coding: 0102142
VCID: 275DB7F6964873061F-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 983 T HW: 4L0 920 983 T
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLN00JU8A
Coding: 2F56630400012600010400
VCID: 43850366C230BF2623-8016
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 G
Component: Heizgeraet H09 0140
Revision: 0000000C Serial number: 00000009021078
Coding: 0000101
VCID: 60CFECEAB3E6C43E1E-8034
1 Fault Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
008 - Implausible Signal
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 P HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0047
Revision: LB200032 Serial number: 3200L10724029F
Coding: 00CF07
VCID: 3C77789ABFCEC0DE62-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H16 0038
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 127642 km
Time Indication: 0
Date: 2016.06.01
Time: 11:05:48
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.40 V
Count: 7
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 H HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7870
Revision: --H03001 Serial number: 15.1528-0123.2
Coding: 0015510
VCID: 2F6D5FD6BEB82B46D7-807A
1 Fault Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 68
Mileage: 127021 km
Time Indication: 0
Date: 2015.12.31
Time: 16:13:22
Freeze Frame:
Error Code: 68
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000023222
Coding: 01010101000000000000000202
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0361
Revision: Serial number: 0004000152784
Coding: 011F06205061440004
VCID: 489F144AFB169C7EF6-801C
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01339897230000
Coding: 3809531
VCID: 35616DBE5CE411969D-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0040
Revision: CH003000 Serial number: 00000000004157
VCID: 2643BAF251426A0E24-8072
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 68
Mileage: 125709 km
Time Indication: 0
Date: 2015.11.27
Time: 17:57:57
Freeze Frame:
Bin. Bits: 00000001
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000178281
Coding: 0011101
VCID: 5EB3D2128992F2CE2C-800A
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0004000152970
VCID: 479D1776F6089306FF-8012
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000008
VCID: 3F8D0F966ED8DBC647-806A
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 053 HW: 4G0 035 053
Component: Radio U Basic H51 0051
Revision: AB001007 Serial number: 496H10A7542383
Coding: 010003010000000000
VCID: 5BB5DB065A80E7E64B-800E
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4L0 035 670 B HW: 4L0 035 670 A
Component: H-BNT-EU H49 0143
Revision: -------- Serial number: 474H.0A7537115
Coding: 010101060004D3EF01000315EF6300030000
Shop #: WSC 00618 210 92061
VCID: 275DB7F6564873061F-8072
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1107
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 B
Component: E0380 Bedient H05 0060
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0004000152194
Coding: 010E06204061230004
VCID: 46831A72F1028A0E04-8012
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0741FY
Coding: 1021001
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H55 0500
Revision: --H55001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD788DA4F2E905EB2-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD24.08.10--H55001001A0295ÿ
Subsystem 4 - Serial number: 1A0295ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0070
Revision: AAH05061 Serial number: 107053772-----
Coding: 0000001
VCID: 65C1FDFEACC4A116ED-8030
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0361
Revision: Serial number: 0004000152204
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H02 0100
Revision: 00H02000 Serial number: 85131022409055
Coding: 0221066
VCID: 2C5748DA8FAE505EF2-8078
End-------------------------(Elapsed Time: 03:15)--------------------------
Wednesday,01,June,2016,12:11:56:42343
www.Ross-Tech.com
VIN: WAUZZZ4L7BD007980 License Plate: PK60AEO
VIN: WAUZZZ4L7BD007980 Mileage: 127640km-79311miles
34-Level Control -- Status: OK 0000
47-Sound System -- Status: OK 0000
Readiness: 0 0 0 0 1
Serial number:
Coding: 001578
Revision: 00H02001
Coding: 2200689
Coding: 0000211
Coding: 01009416
Coding: 0033121
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 0014129
Coding: 0102142
Coding: 0000101
1 Fault Found:
Coding: 00CF07
Coding: 0015510
Coding: 3809531
Coding: 0011101
Coding: 0000008
Coding: 1021001
Coding: 0000001
Coding: 0221066
End-------------------------(Elapsed Time: 03:11)--------------------------
