Thread: The new Q7 smartphone interface
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 115
  1. Re: The new Q7 smartphone interface
    New Forest
    80 Post(s)
    I've just left mine at Poole Audi for it's first 'service' (oil-change and inspection) and have left a note asking about why Android Auto doesn't work, so will see what the response is this afternoon. The loan car is a TT TFSI on a '66' plate. It's rather nice and accelerates and brakes well. I wouldn't swap my Q7 for it though.
    Sent from my STV100-4 using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  2. Re: The new Q7 smartphone interface
    Nov 2016
    Warsaw, Poland
    Quote Originally Posted by andyhud007 View Post
    Mozart I cant quite understand what your asking. ACC in the MMI but you have ACC?
    What do you think your missing?
    Andy
    I have ACC, I have also Predictive information eg roundabout ahead, etc, I have road sign recognition. But I don't have possibility that ACC can adapt the speed to the area speed limit based on signs.
    It can be set in MMI in Drive assist - Adaptive Cruise Control - Use speed limit. I don't have Adaptive Cruise Control option So I thought I had older software.
    Thanks.
    Mateusz
  3. Re: The new Q7 smartphone interface
    Nov 2016
    Warsaw, Poland
    Hi Srbsq7,
    I think I have all 3, but to be sure let's clarify what is exactly predictive efficiency assist. Is it just a pack of information showed on green (in ACC section in Virtual Cockpit) like roundabout or slow down speed limit etc? If so, I have all of them, but using speed limit from signs doesn't work.
    Unfortunately, it is very painful talking to this Audi service, because their first answer is either: "it's ok, it should be that way" or "sorry, your car doesn't have this option". But since I'm stubborn I have now fixed driver's seat, working phonebox etc
    cheers
  4. Re: The new Q7 smartphone interface
    Mar 2010
    37 Post(s)
    228 Post(s)
    You have all the right hardware by the sounds of things. Sounds like some missing coding more than anything.
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  5. The new Q7 smartphone interface
    Jul 2010
    uk
    183 Post(s)
    Quote Originally Posted by Mozart View Post
    Thanks.
    Mateusz
    Hang on someone in the early days had the ACC option in MMI missing...there's a thread here somewhere
    Edit: Mozart is this the issue?
    Predictive Efficiency Assistant
    https://r.tapatalk.com/shareLink?url...0&share_type=t
  6. Re: The new Q7 smartphone interface
    Mar 2010
    37 Post(s)
    228 Post(s)
    Good shout Nemo! Those build weeks where the cars weren't coded correctly!
  7. Re: The new Q7 smartphone interface
    Apr 2016
    Stansted
    169 Post(s)
    Thanks.
    Mateusz
    It does sound like something isn't right there. If you see the green foot coming off the accelerator when you approach roundabouts you have the predictive efficiency assist. I think you also have the Efficiency option in drive select?
    Just checked the manual, and the place to turn it on or off is: MENU button -> Car -> press left control button -> Driver assist -> Audi Adaptive cruise control.
    Under there, you should have "Use Speed Limit" and "Adaption to route ahead". If this is missing, sounds like you have the software issue Deano179 had in the thread you provided a link to. If so, definitely fight with Audi to get it fixed as this is one of the best features.
  8. Re: The new Q7 smartphone interface
    Nov 2016
    Warsaw, Poland
    Guys,
    Yes, I agree there is some problem with software. In my previous post I also put a link to this thread where problem was similar and solved after update.
    But, my software version is 0358, which is the same that solved problem from that thread. I even got info how to run engineers menu, but there was no option for this and I didn't want to mess with it without manual
    Furthermore, In Audi service they didn't want to install anything just because, they told me that it is possible only when there is service action for it. Also according to them I have the latest version.
    Thanks.
  9. Re: The new Q7 smartphone interface
    Apr 2016
    Stansted
    169 Post(s)
    Hi Mateusz,
    Are you in the UK? Might be worth raising with Audi UK if you're not getting anywhere.
    It does feel like we're in a transition period where dealerships are not up to supporting their customers on the tech aspects of the cars (this isn't just an Audi thing as my experience with BMW wasn't any better).
    The factory push out a lot of beta software and have virtually no support structure to deal with any issues.
    I think they need to sort this out or the tech led companies like Tesla will take over in the next decade.
    Can you imagine going into your local dealership in a few years time once that Nvidia / Audi Q7 demo'd at CES a couple of weeks ago goes into production! My Q7's AI is misbehaving, please can you fix neural network and give it a hoover and wash too
    Former Q7 owner
  10. Re: The new Q7 smartphone interface
    Mar 2010
    37 Post(s)
    228 Post(s)
    It will be missing coding. I'm on 0358 and have it. There is newer software for mmi but that's just the mmi software, not the car as a whole.
    0358 doesn't reflect the overall software level of the car, there are many levels for each module in the car. The mmi is just one module on 0358.
  1. Car-net linking to smartphone
    By ZenDog in forum Passat - B8 Forum - 2015 -
    Last Post: 07-06-2016, 05:15 PM
  2. Xcarlink Sat Nav and Wireless Smartphone Mirroring
    By dph1975 in forum In Car Entertainment
    Last Post: 02-10-2015, 10:18 AM
  3. ODB II Bluetooth & Smartphone
    By motionpotion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-02-2015, 07:06 PM
  4. Question Smartphone for Touareg Premium Kit
    By The Scotsman in forum New Member Introductions
    Last Post: 18-01-2009, 01:01 PM
  5. help with interface
    By and32 in forum VCDS - General Questions
    Last Post: 08-12-2008, 11:08 PM
