Thread: 2005 Audi A6 possible electrical fault
  1. 2005 Audi A6 possible electrical fault
    Jan 2016
    Kent
    Dear all,
    Thanks for your patience, and I hope I can be as informative as I can, apologies for my absence.
    Does anyone have any clues on where to start checking.
    Saturday car drives fine..... Sunday did not use it.
    Monday start engine....
    Dash lights are on for ABS, ESP, and the engine light at the top.
    I also in addition have bulbs that are not working according to the warning (they are)
    The electronic handbrake is not working
    the speedo is not working and also therefore not clocking miles (the rev counter is)
    the cruise control is not working
    the parking sensors are not working
    the steering is heavier, there is some power assistance but it is heavier than usual.
    these are only what I have discovered so far... unsure if there is anything else.
    The car drives fine and works providing i dont need any of the above....
    I am merely guessing at the potential electrical fault as how can so much go wrong so suddenly?
    if anyone can shed any light on where to start, I would be grateful.
    someone has suggested the ABS ecu?
    Many thanks in anticipation
  2. Re: 2005 Audi A6 possible electrical fault
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    1. How old is your battery? 2. get a VCDS scan before making expensive choices.
  3. Re: 2005 Audi A6 possible electrical fault
    Aug 2006
    Thessaloniki, Greece
    Have a VCDS scan and post the result here. I'm thinking that either the battery or the regulator of the alternator need changing or even both.
    I had similar dash lights showing and car died while driving in low speed luckily and it was fixed after changing the above.
    Sent from my Nexus 6P using Tapatalk
    2006 Audi A6 Allroad 3.0 TDI Tiptronic
  4. Re: 2005 Audi A6 possible electrical fault
    Mar 2009
    Montenegro
    13 Post(s)
    It is obviously some power supply problem. Must do diagnostic scan.
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  5. Re: 2005 Audi A6 possible electrical fault
    Jul 2007
    glasgow
    35 Post(s)
    first check, is the alternator belt intact ?
    then battery check to see if you have a dud cell(s) ............usually free check
    then check alternator output .
  6. Re: 2005 Audi A6 possible electrical fault
    Jan 2016
    Kent
    Hi thanks for the responses.... despite all the electrical faults I have only one fault code showing
    P0600 Serial Communication Link....
    My fuel gauge has now started to mess around randomly telling me am out of fuel and the gauge randomly moves up and down.....
    Any further ideas please
  1. Please Help Audi A6 S Line 2005 Multiple faults maybe or electrical fault?
    By mippy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-01-2016, 02:41 PM
  2. Please help! Audi A4 1.9tdi injector electrical fault
    By simplelearning in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2015, 01:09 AM
  3. Please Help Audi A4 strange electrical fault
    By joannelut in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2010, 08:26 PM
  4. audi a4 electrical fault???
    By tonyarnold in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2008, 11:37 AM
  5. Audi A4 electrical fault
    By Deoman_3k in forum Chat - Anything with wheels
    Last Post: 23-02-2008, 08:15 PM
