Thread: Coolant Hose Leaking onto DPF
Results 1 to 10 of 13
  1. Coolant Hose Leaking onto DPF
    Jul 2008
    Morning All,
    I was on a drive back from the coast yesterday and noticed steam coming out of the engine.
    My immediate thought was 'OH SH!T'...
    Looked into the engine bay and the and there was a coolant hose leaking coolant directly onto the DPF (or what I think is the DPF).
    I had the EGR valve and cooler replaced a couple of weeks ago - not sure if this is an issue that could have been caused by Audi at the time.
    I'd like to get it rectified quickly - if it's just the hose, then I will get an indi to sort it out rather than going back to the dealer.
    My concern is, if I allow it to continue to drip on the DPF, will there be any major issues? I doubt it will regen if it being cooled constantly. I will get it sorted tomorrow or the day after, but need my car for work.
    Also, if anyone can identify the pipe in question (attached to the silver part - I assume this is a part of the EGR system, a part number would be amazing) it would be appreciated.
    Regards.
  2. Re: Coolant Hose Leaking onto DPF
    What car/engine do you have?
  3. Re: Coolant Hose Leaking onto DPF
    Jul 2008
    Ah! I knew I forgot something.
    2012 A6 2.0 TDI Saloon 180PS S-Line
  4. Re: Coolant Hose Leaking onto DPF
    Looks like #7 in this diagram?
  5. Re: Coolant Hose Leaking onto DPF
    If it is that, which is a coolant hose into the EGR, then there shuold be a clip on it - you can see the marks in your picture where there was a clip but it is now missing.
  6. Re: Coolant Hose Leaking onto DPF
    Jul 2008
    That's the exact one - there is a clip as you mention.
    Do you have the part code by any chance - I will get it ordered today.
    Thanks for your help!
  7. Re: Coolant Hose Leaking onto DPF
    It's just a hose clip
    I think it is N 906 870 01
    27mm x 12mm
    What's your engine code (four letters?)
  8. Re: Coolant Hose Leaking onto DPF
    Jul 2008
    I apologise - I meant the hose you referenced in your picture is the correct hose (i.e. the one that is leaking).My picture isn't clear, but the clip is there - I think it's camouflaged by the dark hose.
    I can't get to the car now, but will provide the engine code when I get the chance.
  9. Re: Coolant Hose Leaking onto DPF
    OK, so you want the part number for the hose?
  10. Re: Coolant Hose Leaking onto DPF
    Jul 2008
    Please
  1. hole in coolant hose
    By simon rampton in forum Golf MK5 - 2004 - 2009
    Last Post: 29-03-2015, 04:13 PM
  2. Coolant hose help please
    By IanHowe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-03-2014, 07:12 PM
  3. I removed my rear wiper, but the water hose it still leaking?
    By Sebseb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-10-2013, 07:21 PM
  4. Rear washer hose leaking
    By dilly2008 in forum Chat - Anything with wheels
    Last Post: 06-06-2012, 10:52 AM
  5. Replies: 2
    Last Post: 23-08-2010, 12:45 PM
