Thread: A6 Allroad AKE 2.5 TDI I am lost
Results 1 to 9 of 9
  1. A6 Allroad AKE 2.5 TDI I am lost
    May 2016
    Inverness
    Hello I am new here and have been going round in circles for weeks reading all I can but can't find anything that specifically fits my problem.
    Background:
    The car sat for 1 year almost 1.5 years after a fair bit of cranking the car started and I drove the car home 30 miles with no issues loads of power no dead pedal ect then switched it off and from there on no start. There was air bubbles in the fuel ling to the distributor pump I eventually traced this back to a damaged O ring in the return valve on the filter.
    I fitted a new filter filled it with fuel ect still no start
    I used a vacuum pump on the filter outlet to pull fuel forward to the filter still no start
    I have fill the pipe to the distributor pump pulled fuel forward connected everything back up crack injector 23456 bubble and some fuel but still nothing
    I have used a multimeter at the EDU there is a 12v supply and earth at pins 8 and 9
    K lines 1 and 2 have the correct voltage
    At pins 5 and 6 there is battery voltage suggesting the ecu is sending a shut off signal to the fuel solenoid valve and from what I understand is that there should be no power at pin five unless the key is turned off and only for about 3 seconds to stall the engine.
    Before I declare the IP dead I need to find out why there is power to pin 5 where are the relays on this car? I am hopping its a dead relay after I truned the car off it got stuck in kill engine position and therefore getting a fault code from the pump. I have read 100 of hours and I am totally lost now I need someone that knows...
    Here are the fault codes before I cleared them to rescan the system
    Code:
    5 Faults Found:
    00542 - Needle lift Sensor (G80)
                30-10 - Open or Short to Plus - Intermittent
    17978 - Engine Start Blocked by Immobilizer
                P1570 - 35-00 -
    01442 - Misfire due to Lack of Fuel
                35-00 -  -
    00519 - Intake Manifold Pressure Sensor (G71)
                31-00 - Open or Short to Ground
    00553 - Mass Air Flow Sensor (G70)
                31-10 - Open or Short to Ground - Intermittent
    Readiness: N/A
    I cleared the codes and tried to crank the engine and got these
    3 Faults Found:
    01318 - Control Module for Injection Pump (J399)
                37-00 - Faulty
                49-00 - No Communications
    Readiness: N/A
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 4Z7 927 156 H
       Component: AG5 01V 2.5lTDI RdW 1818
       Coding: 00001
       Shop #: WSC 00000
       VCID: 4B92FF0379D6B766F3-5072
    5 Faults Found:
    17090 - Transmission Range Sensor (F125)
                P0706 - 35-10 - Implausible Signal - Intermittent
    18232 - Pressure Control Valve 3 (N217)
                P1824 - 35-10 - Open or Short to Ground - Intermittent
    18227 - Pressure Control Valve 2 (N216)
                P1819 - 35-10 - Open or Short to Ground - Intermittent
    18222 - Pressure Control Valve 1 (N215)
                P1814 - 35-10 - Open or Short to Ground - Intermittent
    18237 - Pressure Control Valve 4 (N218)
                P1829 - 35-10 - Open or Short to Ground - Intermittent
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389
       Component: ABS/ESP allrad      D57
       Coding: 06357
       Shop #: WSC 02325
       VCID: 091E050B332AE57601-5000
    1 Fault Found:
    01119 - Gear Recognition Signal
                35-10 -  -  - Intermittent
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 D
       Component: Airbag 8.4E         3000
       Coding: 0001106
       Shop #: WSC 02325 785 00200
       VCID: 50A8E86FC0F094BE86-5072
    1 Fault Found:
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded - Intermittent
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 J
       Component: KOMBI+WEGFAHRS. VDO D09
       Coding: 04460
       Shop #: WSC 00186
       VCID: 2D56919BE7029956CD-5000
       WAUZZZ4B32N070446     AUZ7Z0A1974469
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
                53-10 - Supply Voltage Too Low - Intermittent
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 E
       Component:  - 2C1A1          D040
       Coding: 25500
       Shop #: WSC 09999
       VCID: 479AC33365BE5306D7-5072
    1 Fault Found:
    01400 - Suspension Level Control
    I charged the battery over night and cleared the above codes and got these
    3 Faults Found:
    37-00 - Faulty
    The wire to the lift sensor is goosed found a needle lift sensor but dose not post the the Scottish highland.... as far as I am aware this would not cause a no start as the ecu can gather other information to run the engine?
    I am checked the resistance of the PSG5 (EDC on the pump) and it is with in spec resistance wise at least. I have read a handfull of times about pump fault codes appearing with lack of fuel and then after proper bleeding the codes dont show up again is this true?
    Another clue might be that the alarm system is playing up I tried the procedure in the manual to disarm the anti theft system and then the car would sarcastically unlock its self and if you manage to lock it the alarm goes off the interiör monitor switch does nothing. The car has been lock for two days now and no alarm singal yet. I have left the battery leads off for 24 hours and was never asked for a radio code is there anything chance the cluster is faulty here is a list of moduls the scanner picks up.
    Address 01: Engine
    Protocol: KW1281
    Part No: 4Z7 907 401 B
    Component: 2.5l/4VTEDC G000AG D06
    Coding: 01016
    Shop #: WSC 02325
    Protocol: KW1281
    Coding: 00001
    Shop #: WSC 00000
    Protocol: KW1281
    Coding: 06357
    Shop #: WSC 02325
    Address 15: Airbags
    Protocol: KWP2000
    Coding: 0001106
    Shop #: WSC 02325
    Protocol: KW1281
    Coding: 04460
    Shop #: WSC 00186
    Address 25: Immobilizer
    Protocol: KW1281
    Part No: Bitte Adress
    Component: e 17 eingeben
    Address 33: OBD-II
    Protocol: ????
    Part No: OBD-II/EOBD, Protocol Keyword: $0808
    Protocol: KW1281
    Coding: 25500
    Shop #: WSC 09999
    Address 7E: Ctrl Head Dash
    Protocol: KWP2000
    Part No:
    Note: Excessive Comm Errors
  2. Re: A6 Allroad AKE 2.5 TDI I am lost
    May 2016
    Inverness
    These are interesting pages some not in English just right click translate to english
    VP44_senas
    http://ww2.justanswer.com/uploads/mo..._connector.jpg
  3. Re: A6 Allroad AKE 2.5 TDI I am lost
    Jul 2011
    Norway
    Hi, a j399 code is usually bad news but I suggest you first disconnect the battey, then disconnect both the ECU and the injectionpump, reconnect both and the battery again just in case a bad connection between ECU and pump. When you turn the ignition on the pump shall make
    a buzzing sound for a second or so.
    not when we're talking about a J399 code, no
  4. Re: A6 Allroad AKE 2.5 TDI I am lost
    May 2016
    Inverness
    Quote Originally Posted by ametlib View Post
    Hi, a j399 code is usually bad news but I suggest you first disconnect the battey, then disconnect both the ECU and the injection pump, reconnect both and the battery again just in case a bad connection between ECU and pump. When you turn the ignition on the pump shall make
    a buzzing sound for a second or so. not when we're talking about a J399 code, no
    Hello and thanks for the quick reply!
    Oh dear I had read if you get 120 Ohms over the L1 and L2 that the PSG is Ok but that could be wrong information. I have heard a "buzzing" noise and thought it might have been a short somewhere Ill listen again to see if I can locate the buzzing noise.
    I have just pulled and checked the relays some had corroded connections but nothing sever
    I have also pulled the ECU and the pump again
    Shorted + - off the battery for 15 seconds
    Built a gravity feed tank.
    Battery on charge
    Hoovered out the plumen well or what ever its called
    I could check the big long looking relay thingys no resistance across any of the pins of either unit
    When testing the resistance of the switch in the fuel pump relay there was a slight resistance when it was not energised but only for a second or less
  5. Re: A6 Allroad AKE 2.5 TDI I am lost
    Jul 2011
    Norway
    As long as you have a J399 code present I just can't see the engine starting . The fact that you have the code means you can communicate with the ECU , but also that the ECU cannot communicate with the Injection pump ....
  6. Re: A6 Allroad AKE 2.5 TDI I am lost
    May 2016
    Inverness
    Time to bite the bullet I guess whats the best way to have the pump tested take the car to a garage like a audi garage and have them plug the pump in can they do that ? or do I have to remove the pump? I have seen a recon pump from Germany for £575 pre programmed they say 200 euro deposit until arrival? Dose that mean I get 200 euro back when they recieve me old pump? the mind boggles I wonder if it is worth getting a part ex recon engine for £976
    Thanks for taking time to help me out
  7. Re: A6 Allroad AKE 2.5 TDI I am lost
    May 2016
    Inverness
    So this is the next sateps I guess
    EDC diesel pump testing info test equipment common rail
  8. Re: A6 Allroad AKE 2.5 TDI I am lost
    May 2016
    Inverness
    This was taken from the above page as I thought it might be handy for other users
    A suspect dead VP44 pump can be tested in situ.
    PSG5 only.Check for battery voltage to pin 7, and a good earth to pin 6. The two canbus connections can also be tested with an oscilloscope. Most problems are associated with bad connections which are prone to trouble when passing high currents. The supply to this type of pump is fused at 30amps. VP44 pumps normally fail due to a lubrication issue of the distributor rotor similar to the Lucas/CAV series. In common with the Lucas pumps, fuel and hence lubrication is cut off to the rotorhead during conditions of overrun & engine braking. Any restriction in fuel supply to the pump, for instance a partial filter blockage could also cause damage to the pump, through lubrication starvation. Early models were quite prone to failing, within the distributor rotor assembly, which has been through three different updates since the pump was first made. Later pumps are therefore more reliable in this respect. Another common fault causing instant failure, is the position sensor. It is connected to the main FPCU (fuel pump control unit PSG5-16, mounted at the top of the pump) by a rather delicate IBM type ribbon cable. The position sensor is a set up of three coils and is not a hall effect device, as commonly believed by many in the trade. Should you attempt to remove the pump control unit to expose the position sensor. Not the easiest of jobs! The average DC resistance of these is around 77-85 ohms, when in good order. Another instant failure is caused by the front delivery spooling solenoid valve internal electrical coil collapses, this solenoid is positioned between the output injector pipes. This solenoid can be tested in situ by severing the connecting wires and measuring for a resistance in the coil or connecting to a 15amp supply from the battery, the engine should start and rev very high, should the engine start using this method, it will not run very well due to no control being taken over the lower advance spooling solenoid. It is commonly thought that the top mounted Bosch EDC control module is very weak. We have found these modules to be very robust and do not account for many pump failures. When they do fail it’s normally the switching circuit inside the pump module supplying the upper 15amp IE volume spooling solenoid & they are not that expensive even thou they are only manufactured by Bosch in Spain. There are a few companies, professing to be able to repair these modules. I have my doubts on these claims, personally I think they just fit new silicon hybrid boards and pump assign them. If its reliability your after, I think the former is the only repair action worth considering.
    VP30 - VP44 pulley timing. I had to add this, as several people have enquired, if we can put the floating pulley back on after they have removed the front pulley mounting bolt by mistake. Yes we have jigs and pins in house, to do this without having to mount the pump on a test rig and spill it up!
    VP30 Focus pump timing pictures
    Fuel sampling. Draining the contents of the diesel filter into a glass jam jar, will tell you allot about the state of a diesel pump on a non running vehicle. Should when viewed against a light source, you can see metallic debris floating in it. This will indicate the pump core-rota-plunger is at fault! Simple low cost diagnostics.
    How to confirm if you have a programmable diesel pump? This is simple. Just erase all codes in the main ECU, then turn ignition off, disconnect the PSG5 plug from the pump module, then turn ignition on, re-read stored codes. Should a code relating to CAN-BUS be stored in the main ECU, you have a programmable pump. There seems to be allot of mixed information about in the trade on this subject. So don't assume anything, find out yourself, with the above method!
    PSG16 (Twin plug pumps) This Bosch 44 terminal version contains a read/write 16bit flash memory in the PSG16 module. Where the engine management maps are stored. We do not encourage any user testing on these models. Other issues are that the headers are pump assigned which you cannot change or interchange between used pumps, spooling solenoids are the same as the PSG5 units and can be interchanged.
    PSG5 pumps have one plug, PSG16 plugs have two!
    Common rail injector testing (running leak off method). Connect correct internal diameter tubes to injector leak-off ports. Plug the leak off venturi on high pressure pump to prevent airlocks in the low pressure circuit and spillages. Start-run the engine for a few seconds, all bottles should have the same amount of diesel in them after the test run at idling speed. Any bottle with more fuel in it than the others. Will indicate a fault with the injector connected to the bottle in question. It is possible for the injector to have a fault and have less in the bottle, but normally a faulty injector will leak off more fuel due to, worn internal injector components. If a bottle has a lower volume in it, the chances are the coil in the injector is not being activated due to a dysfunctional internal injector coil or bad host wiring to it, or no signal being sent to it from the ECU. Most adapters can be bought for low cost. An eceptable leak back is about 20ml for 2 minutes idling.
    Common rail injector solenoid testing in situ. The fuel injection process starts with a voltage being applied to the solenoid valve with a pull-in current of about 12 amps. During the injection state of the process, the current applied to the solenoid valve is reduced to half of the pull-in current i.e. 6 amps. This value is sufficient to maintain the injection control valve in the open position. You will need a sensitive DC inductive clamp attachment with a shielded cable, attached to an oscilloscope set to display a time scale to view solenoid control valve waveform which has a switching time of approximately 0.3 milliseconds. I find it quicker to test this type of injector in situ, than removing them. With a set of four injectors, if you get 10 amps pull-in on three & 5 amps running, but the fourth injector does not match these values. You've found the fault. How much current is not the issue, its if the values matching across the set of injectors, which counts. With the exception of very low current readings on a complete set of injectors. Which would point to a bad electrical supply. Or very low fuel pressure in the rail. Simple theory is, to overcome 1000bar plus of pressure with an electrical solenoid valve, a reasonable amount of current will be needed.
    Note. Most injectors are coded for position. If not, all injectors are calibrated to take into account manufacturing tolerances. IMA or QR code for injector flow adjustment. These calibrations are indicated on the exterior of the injector by a code. The code is used by the EDC-ECU to adjust the duration of the injection cycle. If the codes for the individual injector's are incorrectly matched to the codes stored in the ECU, the engine may exhibit rough idle, increased combustion noise and black smoke emissions. These facts excludes the fitting of secondhand injectors. As a matter of information, we do not recommend ultrasonic cleaning for any injector with an electrical connection. Some companies do enact ultrasonic cleaning. I do not...! I believe it affects the long term reliability of the electrical components. We have needed to use an injector seat cutter for refitting common rail injectors. Only exception, when may need one is for a Mercedes Vito, if the injector seats have been leaking. But normally the cylinder head is past restoration and will need an expensive replacement.
    Common rail injector static test leak off test (if engine cannot be started). Connect correct internal diameter tubes to injector leak-off ports. Plug the leak off venturi on high pressure pump to prevent airlocks in the low pressure circuit and spillages. Disconnect the inlet pump pressure metering valve connector and/or injector electrical connectors, some engine set-ups require injectors to be connected others need them to be disconnected. Crank the engine for ten seconds. Any injector with excessive back flow should be replaced (check the specs for your make). The basic theory here is, if you remove the electric connector to the pump pressure metering valve the pressure will ramp up to maximum (not for the faint hearted). Only complication here is, a very few pumps have a volume valve as well as a metering valve. Some setups have the pressure metering valve on the rail not the pump.
    Common rail pressure sensor voltages. Typical values (Bosch EDC16) Rail pressure sensor.
    Engine stationary 0.5 volts DC
    Engine idling 1.32 volts DC
    Snap acceleration 3.77 volts + DC
    Common rail high pressure pump testing in situ. Dynamic pressure tests are not encouraged by manufacturers, easy to say when you have all the kit and a stores dept packed with spare injectors & pumps to fit and try. With the inlet metering valve disconnected it allows full fuel pressure of up to 1600-1800 bar to be delivered. However at idle speed with everything connected the fuel pressure is only about 300-400 bar, which will give a fair indication of what is going on. High pressure dynamic testing should be the last resort, i.e. only if the engine can't be started. Most vehicles will need a cranking pressure of above 200-300 bar to start. Your only hope for measuring this value is serial data, using diagnostic equipment from the rail pressure sensor. Physical gauges are available which measure up 2000bar, but I can't see the benefit over serial data.
    Injector Leak Off Testing.
    This set retails at over £45
    Mercedes 270 CDi leak off testing. No 5 injector failed (near orange pipe clamp)
    If your diagnosis is not conclusive. We can electronically bench test for pressure-volume by phasing & repair most common rail injectors, via return of post. common rail injector testing info
    Water, poor quality diesel and fuel restrictions wreck diesel injection pumps. Use good clean fuel and change your filter!
    EDC 15 M wiring diagram Vauxhall Astra Vectra 2.0DTi
    info on EDC pump numbers-applications
    VP44 Electronics
    Bad news!
    More bad news!
    Repair!
    VP44
    Testing-Bosch VE EDC diesel pump actuator. The actuator below is a common failure internally within the Bosch VE EDC diesel pump range.
    Below is a comprehensive table for fault diagnosis-testing the VE actuator.
    Designation Unit Set Value Min Max
    POSITIONER TESTING
    Test temperature deg. C 22.5 15.0 30.0
    Impedance, connections 4 & 7 ohms 0.7 0.4 1.0
    Test temperature deg. C 60.0 50.0 70.0
    Impedance, connections 4 & 7 ohms 0.775 0.450 1.100
    Impedance, connection 4 & ground M ohms 1.0
    Impedance, connections 2 & 7 M ohms 1.0
    Impedance, connections 4 & 6 M ohms 1.0
    Impedance, connection 7 & ground M ohms 1.0
    HALF DIFFERENTIAL INDUCTIVE PICKUP
    Impedance, connections 1 & 3 K ohms 5.7 4.9 6.5
    Impedance, connections 2 & 3 K ohms 5.7 4.9 6.5
    Impedance, connections 1 & 2 K ohms 11.4 9.8 13.0
    Impedance, connection 1 & ground M ohms 1.0
    Impedance, connection 2 & ground M ohms 1.0
    Impedance, connection 3 & ground M ohms 1.0
    FUEL TEMPERATURE SENSOR
    Impedance, connections 5 & 6 K ohms 2.6 1.2 4.0
    Impedance, connections 5 & 6 K ohms 0.75 0.30 1.20
    Impedance, connection 5 & ground M ohms 1.0
    Impedance, connection 6 & ground M ohms 1.0
    SOLENOID VALVE START OF DELIVERY
    Impedance, connections 1 & 2 ohms 15.8 14.3 17.3
    Resistance connections 1 & 2 ohms 18.25 15.50 21.00
    EXCESS-FUEL STOP/SHUTOFF STOP
    Excess-fuel stop M volts 4385 4120 4650
    Shutoff stop M volts 750 650 850
  9. Re: A6 Allroad AKE 2.5 TDI I am lost
    Jul 2011
    Norway
    Maybe time to call Diesel Bob ?
  1. Allroad Coolant Expansion Tank - 2.5 TDI AKE
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-05-2014, 04:18 PM
  2. Allroad 2.5 tdi ake suspension puzzling problem
    By RICK2472 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-07-2013, 10:06 PM
  3. English Version of the SSP for the Allroad 2.5 Tdi AKE Automatic
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2013, 02:24 PM
  4. Dianostic codes audi allroad 2.5 TDI AKE ENGINE
    By tony01 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2012, 06:26 PM
  5. Replacing Timing Belt on allroad 2.5 TDi AKE 2002
    Last Post: 29-11-2011, 09:53 AM
