Thread: Mk5 Golf 2.0 FSI, Engine stutter/choke and cut outs?
  1. Mk5 Golf 2.0 FSI, Engine stutter/choke and cut outs?
    Feb 2016
    Norwich
    I've got a 2005 Mk5 Golf 2.0 FSI, Engine code: BLX.
    A few days ago my car started juddering at random times in all gears, it was quite violent and was pretty scary to drive! It almost feels like the engine isn't getting enough fuel and is failing to run the engine.
    I also occasionally lose all throttle response and the engine will not rev or pick up speed, slowing down until it either suddenly bursts back to life(depending on what throttle I have down) or stalls...
    I also noticed that when it happened today, I was going about 20mph and It felt like the engine had stalled(I had lights ping up and red battery light come on briefly) before springing back into life and throttle started responding again... I'm at a loss.
    I took it for a code scan today, I didn't get the error codes as he wasn't sure if they were recent or old codes. so until I can get the errors to replicate I'm left speculating... I know that there was a fuel pressure sensor error, a few Intake Manifold errors too (Intake manifold tuning valve?), a knock sensor error on cylinder 2 and an o2 bank 1 sensor 3 heating control error(Obviously without the actual codes these are no use to anyone)
    Essentially my(intermittent) symptoms are:
    -Random stuttering/juddering/coughs in all gears
    -Loss of all power when coughing/stuttering AND random loss of Throttle response
    -Erratic idle, ranges between nominal idle speed and around 400-500 rpm lower(revs bounce slowly between the two...sometimes causes the engine to stall)
    I have replaced both the plugs and fuel filter in case it was related to those, however no luck with those... Does anyone have any idea what could be causing this? Or any recommendations on what I should look into first?
    i.e Faulty Fuel pump or some of the intake errors, check grounding points perhaps?
    I'm not sure, Any help is appreciated though!
  2. Re: Mk5 Golf 2.0 FSI, Engine stutter/choke and cut outs?
    buckinghamshire
    I've got a 1.6FSI also 2005 which has done 104k miles. I'm on my third fuel pump and experienced some of the symptoms you describe. If you have VCDS you could go into engine measuring blocks and see what the low and high fuel pressure readings are using a passenger to watch the laptop while you drive.
  1. Mk5 golf fsi engine management light
    By MissKite in forum Golf MK5 - 2004 - 2009
    Last Post: 29-03-2016, 02:25 PM
  2. Please Help engine manaagement light on golf mk5 fsi 1.6
    By nephets in forum Golf MK5 - 2004 - 2009
    Last Post: 20-03-2016, 04:18 PM
  3. Cover missing in engine compartment of Golf MK5 Fsi 04 Reg?
    By lucycampbell in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2008, 07:39 PM
  4. Engine cut outs, warning lights coming on!
    By barnaby82 in forum Archive posts
    Last Post: 04-02-2008, 07:59 PM
  5. Engine Oil Drain Plug Mk5 Golf FSI
    By brentos2004 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-01-2008, 04:17 PM
