Thread: LCD Pixels Repair
Results 1 to 10 of 19
  1. LCD Pixels Repair
    Dec 2009
    Oxted, UK
    My 1999 1.6 8V Auto has started to drop out more LCD pixels.
    What is the best way to repair it?
    Where to go to get it done?
    Regards,
  2. Re: LCD Pixels Repair
    Pembrokeshire
    22 Post(s)
    Bba reman.
  3. Re: LCD Pixels Repair
    Dec 2010
    Worcs, UK
    Which display?
    What speedo do you have (large or small MFA)?
  4. Re: LCD Pixels Repair
    Dec 2009
    Oxted, UK
    As it's an Automatic, with the Gear selection information in the display I'm pretty sure it's the large MFA
    Regards,
  5. Re: LCD Pixels Repair
    Dec 2010
    Worcs, UK
    Are you sure? Maybe post a photo - ideally taken out so part number and manufacturer are visible.
    I know there are half screen ones for automatics - see photos in below ebay ad....
    VW Golf 4 Tacho Benzin Automatik - Kilometerstand frei aenderbar - mit Login/PIN | eBay
    I might be able to fix yours for you, clone it to another unit or fit a used one to your car.
  6. Re: LCD Pixels Repair
    Dec 2009
    Oxted, UK
    I'll get a picture ASAP
    It's definitely a larger screen than that as it has miles to empty and other info on the LCD above the Gear selection
    Regards,
  7. Re: LCD Pixels Repair
    Dec 2010
    Worcs, UK
    If the screen is about twice the size of the one in the ebay link then it is a full MFA and if it has MTE enabled it is immo3 generation (although you can also have MTE on half screen MFA speedos).
  8. Re: LCD Pixels Repair
    Dec 2009
    Oxted, UK
    It's definitely the larger screen then.
    If it is an immo3 what are the approximate costs to repair the LCD?
    Regards,
  9. Re: LCD Pixels Repair
    Dec 2010
    Worcs, UK
    Would need to know which supplier made your speedo (Motometer, BOSCH or VDO).
    Undo the two philips screws at bottom of steering pillar trim, top part lifts off and you can unclip the trim below speedo.
    The undo two TX10 screws that hold speedo in place, then you can tilt it forward and should be able to see manfacturer marking and part numbers.
    Cost will depend on what display is fitted, some need soldering in place (contacts are SMD size so it is pretty tricky).
  10. Re: LCD Pixels Repair
    Dec 2009
    Oxted, UK
    I'll get photos, info etc and post them.
    Thank you very much for your help.
    Regards,
  1. How To How to readjust the instrument needles after messing about with DIS LCD repair
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2016, 04:17 PM
  2. DIS LCD repair company like Cartronix in Southeast?
    Last Post: 28-02-2013, 11:19 AM
  3. Missing pixels
    By Stagecoach in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2012, 09:38 AM
  4. Question LCD Display bleeding pixels
    By mcstu74 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-01-2012, 09:23 PM
  5. DIS LCD Repair guide
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2009, 11:41 AM
