Thread: A5 Convertible
  1. A5 Convertible
    Feb 2015
    North East
    A mate has a 61 plate A5 convertible and the roof won't go down.
    The windows go down but it the roof doesn't move.
    I found these faults using VCDS...Anyone got any idea what the problem is or has a drawing of where the sensors/switches which are mentioned in the faults are?
    4 Faults Found:
    0021 - Convertible Top Compartment Switch; Right
    B1182 29 [008] - Signal Implausible
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 61798 km
    Date: 2016.04.19
    Time: 18:34:50
    0042 - Supply Voltage 1 for Switches and Sensors
    B119E 01 [008] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 28
    Mileage: 61798 km
    Date: 2016.04.19
    Time: 18:33:15
    0043 - Supply Voltage 1 for Switches
    B119F 01 [008] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 28
    Mileage: 61798 km
    Date: 2016.04.19
    Time: 18:33:15
    0045 - Relay for Hydraulic Pump
    B11A2 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 19
    Reset counter: 231
    Mileage: 61798 km
    Date: 2016.04.19
    Time: 18:35:42
  2. Re: A5 Convertible
    Mar 2022
    Southport
    Take it no one was able to help here, same issues with my Wife's, how did you get on?
  3. Re: A5 Convertible
    1836 Post(s)
    Same codes?
  4. Re: A5 Convertible
    Jul 2007
    somerset
    8 Post(s)
    Try googling VAGPRO, they helped when I had issues with my cab.
  1. a4 3.0 convertible - what to look out for
    By jack wahlberg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2012, 09:20 AM
  2. a4 convertible
    By milliemoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2007, 05:40 PM
