Thread: Mk6 gtd timing belt
Results 1 to 10 of 14
  1. Mk6 gtd timing belt
    Apr 2016
    Sheffield
    Hello just had my timing belt and water pump replaced now its making a whining noise between 1500-2300-2500 up and back down the revs could this be that its just a new belt or should i take it straight back anybody had one replaced on this model
  2. Re: Mk6 gtd timing belt
    Pembrokeshire
    22 Post(s)
    sounds like it might be too tight, or something else is wrong. you need to take it straight back. who did it , main dealer ?
  3. Re: Mk6 gtd timing belt
    Apr 2016
    Sheffield
    Ye its been back today they have checked everything and said its all fine just new belt bedding in reassured me its all covered if something went wrong
  4. Re: Mk6 gtd timing belt
    Pembrokeshire
    22 Post(s)
    new belts do not need to bed in and should not whine. it is either too tight or the new water pump is goosed. simple as that. 25 years in the trade and i know things like this..
  5. Mk6 gtd timing belt
    Apr 2016
    Sheffield
    Sent from my iPhone using Tapata
  6. Re: Mk6 gtd timing belt
    Apr 2016
    Sheffield
    Its going back in first thing in morning mate i have told them im not happy with it and i want them to replace all the parts they have fitted is there anything in that area they could have taken off to do the job what once refitted could be causing this noise
  7. Re: Mk6 gtd timing belt
    Apr 2016
    Sheffield
    When the bonnets popped up mate and i get someone to stick some revs on the noise seems to be comming from the rear part of the timming belt housing am i right in thinking this is where the water pump sits
  8. Re: Mk6 gtd timing belt
    Pembrokeshire
    22 Post(s)
    it could be something on the aux belt, but unlikely . chances are they have managed to over tension it or the new pump or a new roller/tensioner is dodgy. it does happen every now and again, but the usual cause of a whine is a belt thats too tight.
  9. Re: Mk6 gtd timing belt
    Apr 2016
    Sheffield
    Ok they did say they had checked the belt and it wasn't to tight even though when they first listened to it. Thats what they had said it was the belt was to tight and tried to convince me it was fine to drive with the belt over tight
  10. Re: Mk6 gtd timing belt
    Pembrokeshire
    22 Post(s)
    its fine to drive yes, until the extra tightness wears out the water pump bearings, the tensioner bearing or the guides bearings, then the belt snaps or wears itself away.
  1. Hello i have a mk6 gtd
    By Davekgtd in forum Golf MK6 - 2009 - 2013
    Last Post: 26-04-2016, 04:16 AM
  2. GTD MPG after timing belt
    By davegilsenan in forum Golf MK6 - 2009 - 2013
    Last Post: 22-11-2015, 07:56 PM
  3. Xenon LED DRL headlight product info query MK6 GTD
    By pauls.hot5 in forum Golf MK6 - 2009 - 2013
    Last Post: 09-11-2014, 10:55 PM
  4. Question front underseat drawer for mk6 gtd ??
    Last Post: 14-10-2014, 07:52 PM
  5. Water drainage from Golf Mk6 GTD door.
    By spencerchappell in forum Golf MK6 - 2009 - 2013
    Last Post: 11-06-2010, 01:41 PM
