Thread: Where's my dashboard lights?
  1. Where's my dashboard lights?
    Apr 2016
    Manchester
    So, I've had my B7 Avant for about a month now and I've realised that some of the dash lights don't work.
    Would I be right in thinking that when I turn on my headlights a little light symbol should come on on the dash to show that the lights are on?
    I've looked closely and I can see a main beam light symbol and a dipped light symbol on the dash but when I turn the lights on they don't light up. Even the fog light on the dash doesn't light up.
    Here's a pic off the web of someone else's dash with the light symbol illuminated...
    2006 Audi A4 B7 Avant 2.0 TFSI S Line Quattro tiptronic in Phantom Black.
  2. Re: Where's my dashboard lights?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    The symbol lit on the photo is just saying lights on, be they side lights or head lights.
    You will see the blue item when on full beam.
    The fog light tell tale for both the front fogs and rear fogs will only light up on the switch surround
    Nothing else on dash, just the lights on symbol as per your photo
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  3. Re: Where's my dashboard lights?
    Oct 2009
    10 Post(s)
    Sorry , just to clarify re fogs, the switch dial and the bit that you pull will show around the rim when fronts and rears are selected
  4. Re: Where's my dashboard lights?
    Apr 2016
    Manchester
    Just to clarify. That pic is NOT my car. As I said its just a pic I found off the web of a b7 dash to help illustrate my point.
    That green light never comes on, maybe I should have made that clearer in my opening post.
    The point is that with my side lights, or main lights on that green light symbol NEVER appears.
    I was simply trying to find out whether there should be a light on the dash when the lights are turned on. Or if there was a light on the dash when the fogs were turned on.
    On my RX8 there was no light on the dash to indicate side or main lights, but when either were turned on the whole dash lit up and looked obviously different to when the lights were off.
    The only light symbol that appeared on the dash was the light that came on when the fog lights were activated.
    Just wondered if there was a fault with my A4 dash light indicator and how to fix it.
  5. Re: Where's my dashboard lights?
    Oct 2009
    10 Post(s)
    I see, yes you should see the same symbol as per the b7 photo and your instrument panels should light up as soon as you select side lights, then onto headlights, no change, full beam blue and fogs only light up on the switch.
    I would suggest a bulb out in your binnacle/cluster. Good luck
    Stuart
  6. Re: Where's my dashboard lights?
    chester
    17 Post(s)
    With ignition on and engine off check whether you get abs light on for a few seconds,some unscrupulous people disable it to disguise a fault.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  7. Re: Where's my dashboard lights?
    May 2009
    Glasgow
    No Sidelight/Headlight on indication on my car. Just Full Beam. Think this is the norm. I have read the lights on indication can be coded though
  8. Re: Where's my dashboard lights?
    May 2009
    Glasgow
    See link below, About 7th reply to post.
    "Side lights" light on dash not coming on? | Audi-Sport.net
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Question Lights on Dashboard - Help!
    By mlettin in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2009, 05:56 PM
  3. Question Lights out on the dashboard?!?
    By hillda01 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2009, 10:03 PM
  4. Help with lights in dashboard A4
    By Johanzen in forum Audi A4 - Archive Topics
    Last Post: 02-11-2007, 02:20 PM
  5. dashboard lights
    By wax in forum Audi A4 - Archive Topics
    Last Post: 11-12-2006, 04:25 PM
