Thread: Rear subframe mount is wet!?
  1. Rear subframe mount is wet!?
    Jul 2014
    South Yorkshire
    A4 s line avant.
    The rear subframe mount, the one nearer to the front of the car is wet with what looks a bit like oil. It's not brake fluid from the lines that run above it..and it's not oil from a shock that's made its way down there! I can't get my head around it...!? I even had the back seat out thinking it may have been something leaking in my boot that has found its way through a hole and down there but nope!
    Joe
  2. Re: Rear subframe mount is wet!?
    Apr 2015
    Scotland
    Probably a daft thought but could it be something leaking from the front that's splashed on the rear as you've driven? Or is it solely on the mount?
    Sent from my E6653 using Tapatalk
  3. Re: Rear subframe mount is wet!?
    Jul 2014
    South Yorkshire
    Maybe? I'll have to have another look at it tomorrow. If I can't work it out I'll take it to my mates on the weekend and get it on the ramps for a proper look. Just weird cause it is only the mount that is wet? Odd!
  1. A3 rear subframe help.
    By dfps in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-02-2015, 06:50 PM
  2. Rear subframe help needed
    By andy h91 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-02-2013, 12:09 PM
  3. Dropping subframe to remove lower rear control arm bolt
    By trevMk2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2010, 09:46 AM
  4. Cracked rear subframe ........prob gonna seriously cost!!!
    By Russboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-06-2009, 05:45 PM
