Thread: Filler cap door won't open.
  1. Filler cap door won't open.
    Jul 2014
    South Yorkshire
    Hey!
    So today I went to put some fuel in my 57 plate tdi s-line avant, and the door on the filler wouldn't open. I could see the pin from the actuator was still in the locked position. So I locked and unlocked the car several times..still nothing. I had a look for a manual release but couldn't see one. Any ideas? I don't think it's linked, infact I'm sure it's not but the other day I noticed a noise coming through my speakers that matched my revs perfectly..I thought it was my turbo giving up at first. I had previously changed the fuse for the fag lighter cause it had never worked so I removed the fuse when I noticed the noise and it was still there. Then I noticed a cracking noise when I opened/closed the drives door..so I wiggled the cables that go from the body to the door and it went away! I doubt it's linked but..!
    Back to the fuel cap..I guess it's the actuator that's had it? Can I acces/ remove this if I strip the boot out?
    Thanks,
    Joe
  2. Re: Filler cap door won't open.
    Dec 2013
    Derby
    If you open where the sub woofer & amp is located in the boot/trunk on the right hand side there should be a manual release that you can pull to release the solenoid pin on the fuel filler cap. It is a plastic loop on the end of a type of cable if I recall correctly.
  3. Re: Filler cap door won't open.
    Jul 2014
    South Yorkshire
    Got it! Thanks a lot. I had to remove the trim and the big plastic bit of clobber that the amp/sub are mounted to...it had managed to drop all the way down. What a pain!
  4. Re: Filler cap door won't open.
    Dec 2013
    Derby
    Glad to be of help dude
  1. Cant open petrol filler cap
    By andyha2000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2009, 05:11 PM
  2. Fuel Filler Cap won't close
    By Astonm in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2009, 12:54 PM
  3. polo fuel filler cap stays OPEN with central locking
    By vpetite in forum Polo - Derby - Lupo - Fox
    Last Post: 30-10-2008, 12:24 PM
  4. filler cap door lock
    By nano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-06-2008, 08:09 PM
  5. 02 Polo fuel filler won't open
    By Midge in forum Polo - Derby - Lupo - Fox
    Last Post: 29-05-2007, 10:37 PM
