Thread: 1999 VW Polo Radio Wiring
  1. 1999 VW Polo Radio Wiring
    Apr 2016
    Sydney, Australia
    I am trying to upgrade the radio in a 1999 VW Polo. Does anyone have a diagram which tells what colour wires relate to what in the factory wiring harness?
  2. Re: 1999 VW Polo Radio Wiring
    It's usually easier to get a harness adapter, to change from OEM><insert manufacturer of head unit here> - cleaner and easier to remove should you need to.
    https://www.installdr.com/harnesses/vw-wiring.asp
    any help?
  3. Re: 1999 VW Polo Radio Wiring
    Apr 2016
    Sydney, Australia
    Thanks for that. I am a bit slow. I eventually found the Eurovox sticker on the radio and found a Eurovox wiring color table. http://www.eurovox.com.au/downloads/...m%20Update.pdf
    However, when I pulled the loom I found the harness adaptor and the original coloring then was a help. and the installdr table was a help.
    I then had to re-pin the new harness adaptor to match the Polo wiring, but all is now installed and working. Part of the issue is that the new system did not have dimmer options.
    Many thanks for the help.
  1. 1.8T petrol 1999 AEB - Wiring diagram - ignition
    By anorak_ian in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-09-2015, 04:38 PM
  2. Instrument Cluster Wiring Diagram - 1999 B5 A4 1.8T
    By Grant620 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-07-2015, 01:39 PM
  3. Question radio wiring
    By nikkiy9 in forum In Car Entertainment
    Last Post: 29-11-2010, 01:15 PM
  4. Wiring Diagram for 1999 A6 1.9Tdi??
    By Alas in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-11-2007, 02:04 PM
  5. radio wiring
    By Coupe Headache in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-10-2007, 03:31 PM
