Thread: Audi A7 Hidden MMI menus?
Results 1 to 10 of 19
  1. Audi A7 Hidden MMI menus?
    Apr 2016
    Congleton
    Does anyone know if there are any hidden MMI menus for the latest Audi A7?
    I know some of the older Audis had a way of getting into the system by pressing and holding a couple of buttons.
  2. Re: Audi A7 Hidden MMI menus?
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by Wippers View Post
    You can try Car+Back for Red Menu.
    The Green Menu must be enabled first via VCDS, and after this you can enter it by pressing and holding Car+Menu.
    You can get more information in the A6/C7 tips&tricks topic.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  3. Re: Audi A7 Hidden MMI menus?
    Apr 2016
    Congleton
    Cheers for the info. Pressing and holding car and menu doesn't seem to do anything? Do I need to have it in a particular menu or something?
    Also, how do you get the green screen enabled and does it effect warranties etc do you know? I don't know anyone who has the VCDS software unfortunately.
  4. Re: Audi A7 Hidden MMI menus?
    Feb 2016
    Hungary
    116 Post(s)
    Yes, as I told, you have to enable the Green menu with a VCDS first. Until then, Car+Menu will do nothing.
    As far as I know, it has nothing to do with the warranty, but all this kind of tips and tricks can cause expensive service bills if you don't know what you do in these menus. The Green Menu in itself usually not a useful thing, it's usage is mandatory to make the VCDS modifications active.
    First please refer to the tips & tricks topic's first page, there you can find all the possible modifications. If you will need something from these, than these can be done in several places. But if you don't need anything from the listed options, then you will not need the Green Menu at all.
  5. Re: Audi A7 Hidden MMI menus?
    Apr 2016
    Congleton
    Sorry I meant the Car+Back option for the red menu. This doesn't seem to work. The only red menu I can get is the standard Car button. Does this also need the VCDS enabled to work?
    Maybe the hidden green menu may could cause me more problems than I'll gain.
    Thanks for your help so far. Very much appreciated.
  6. Re: Audi A7 Hidden MMI menus?
    Oct 2005
    As this doesn't appear to be "[a] topic related to home or business computer and personal technology" I have moved it from Tech Shed to the A7-S7 section.
  7. Re: Audi A7 Hidden MMI menus?
    Apr 2016
    Congleton
    Sorry I thought I'd posted in the Tech section.
  8. Re: Audi A7 Hidden MMI menus?
    Feb 2016
    Hungary
    116 Post(s)
    Maybe you pressed the wrong order: Press the Car first, hold it, press Back, and hold it. Hold these for ~five seconds. This is the regular way to enter the Red Menu. However, as you have a brand new car, maybe this menu was disabled, or maybe it has a different key combination. Never mind, there are not too much interesting things in the Red Menu, you can live happily without it
    Your welcome, enjoy your car
  9. Re: Audi A7 Hidden MMI menus?
    Apr 2016
    Congleton
    Looks like they must have disabled it as no joy.
  10. Re: Audi A7 Hidden MMI menus?
    Feb 2013
    Gloucester
    57 Post(s)
    If you need any VCDS bits doing, have a look at the VCDS users map and it will show you Local people willing to help.
  1. Hidden menus
    By ricky_s in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 06-11-2016, 05:05 PM
  2. Reset hidden menus after MMI update.
    By sti69 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 23-08-2015, 11:44 PM
  3. MMI 2g hidden menu
    By Tim B in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-04-2013, 01:12 PM
  4. Accessing MMI Hidden Menu on Facelift B8 with MMI 3G
    By aled_31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-04-2012, 08:34 PM
  5. MMI Hidden Menu
    By dragondownsouth in forum A8 - S8 - V8
    Last Post: 22-12-2011, 05:22 PM
