Thread: 312 mm brakes
Results 1 to 10 of 14
  1. 312 mm brakes
    Apr 2016
    Falkirk
    Hi guys I've got a 312mm brake set up from a mk5 golf with 312mm a4 discs,will this fit onto my car as I've been told some of the 280mm setups have a different knuckle car is an 04 pd100 avb
    thanks
  2. Re: 312 mm brakes
    Apr 2016
    Falkirk
    Nobody upgrade from 280mm brakes? Just wanting to know if either 288/312mm carriers will fit the knuckles?
  3. Re: 312 mm brakes
    scotland
    39 Post(s)
    Either no one knows or they're not answering, only way to find out is to try it, I do know you'll need to have 16 inch wheels.
  4. Re: 312 mm brakes
    Apr 2016
    Falkirk
    Thanks for your reply calum,I've had the caliper/carrier bolted on with no issues to test it,I've now got new 312mm discs,ferrodo premier pads and suitable flexis so I'm ready to tackle the job,if I can work out how to post pictures I'll put some up as other people may be interested in same upgrade.
  5. Re: 312 mm brakes
    Apr 2016
    Falkirk
    Just the caliper bolted up to test fit
  6. Re: 312 mm brakes
    Pembrokeshire
    22 Post(s)
    just about to bring my s4 in to do the same, test fit the new brakes, but i am going from 321mm discs to 350mm with brembo 6 pots off a porsche cayenne.
  7. Re: 312 mm brakes
    Apr 2016
    Falkirk
    Sounds interesting mate,after remapping my car the brakes are really weak,so hopefully the 312 set up will make a noticeable improvement,you gonna post pics mate?
  8. Re: 312 mm brakes
    Pembrokeshire
    22 Post(s)
    yeah, will get some pics up soon.. the standard s4 brakes work well enough upto a point, but start to fade on fast a roads. shes remapped anyway but i am going for bigger turbos soon so the brakes are in preperation for that. total cost will not be much more than expensive standard brakes, but i did draw the line at the ferodo ds2500 pads which even trade would set me back 300 quid, so went for the trw dtec instead.
  9. Re: 312 mm brakes
    Apr 2016
    Falkirk
    Had a look at the ferrodo ds pads a wee bit pricey for me,went for the ferrodo premiers as they get good reviews,my cars a pd100 remapped to 140 at the moment but I'm after a pd130 turbo and injectors and 3bar map sensor then hopefully push it up to 175ish.
  10. Re: 312 mm brakes
    Pembrokeshire
    22 Post(s)
    looking to fit a pair of tte550 turbos and fuel pump/injectors and get to 550 bhp.
  1. in the middle of starting the 312 and...
    By aks1989 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-04-2015, 05:59 PM
  2. Please Help HELP!!! NIGHTMARE!!! Trying to upgrade from 288mm to 312 discs....major problems
    By rmjohnso in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-08-2012, 10:35 PM
  3. Replies: 0
    Last Post: 26-12-2010, 04:08 PM
  4. Upgrade A6 brakes to S8 brakes
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 10:15 PM
  5. Help with brakes
    By audi fish in forum Audi A4 - Archive Topics
    Last Post: 14-09-2007, 05:21 AM
