Thread: Front struts are loose after lowering springs install
  1. Front struts are loose after lowering springs install
    Mar 2011
    london, uk
    Hi Guys. As the title suggests, both of my struts at the front are loose and I am unable to bolt the tight to the body. Is this right? I have installed the lowering springs last month and when assembling everything it seems like somethings wrong. I can move/wobble the struts with my hands da when the car is jacked up. This doesn't seem right to me. And now I have clunking noise coming from the ftont when going over small bumps. I can not figure out if the struts are supposed to be like that and the noise is coming from somewhere else or I messed something up when assembling?
    Please help!
    Thanks.
    Audi a1 1.4 tfsi 3door.
  2. Re: Front struts are loose after lowering springs install
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Looks like you fitted shorter springs to the original struts ? The springs could now be too loose in the strut when the damper is fully extended. Not sure what you mean by unable to bolt the strut tight to the body - did you get the top mount and nut put back together right ?
    Removing and installing suspension strut
    best sort it as it sounds dangerous at the moment. Doubt your insurance company would cover you in a bump!
  1. Please Help Help please - Re: Front Struts & Springs
    By Grandad Dave in forum Golf MK4 - 1999 - 2004
    Last Post: 07-01-2012, 11:20 PM
  2. Lowering Springs
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-12-2011, 07:53 PM
  3. For Sale Spax adjustable suspension struts and lowered springs
    By kernowk in forum 80 - 90
    Last Post: 12-08-2011, 09:41 PM
  4. Front 30mm lowering springs
    By brightside in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-03-2011, 11:44 PM
  5. Best lowering springs
    By skimd in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2009, 09:52 PM
