Thread: your opinions needed asap
  1. your opinions needed asap
    Jan 2008
    nottinghamshire
    hi the missis a4 had a accident, which had damaged the back 1/4 and the back wheel
    the car has been repaired but now there is a warnign light on, i think its the traction control light
    the garage have said it has been plugged in and it the steering angle sensor ( the one on the steering wheel) they say it has nothing to do with the accident and there not fixing it.
    there wasn't any warning lights on before the accident.
    the insurance company have said that we have to take it to get it plugging in at audi (at our expence) and if the problem is accident related they will fix it.
    my question is that would an impact on the back wheel throw on a warning light
    or is it possible that the garage who have repaired it have messed something up, as they told us that after fitting the rear quarter panel they was expecting the airbag light to come on and usually they reset it, but they said the airbag light didnt come on and the traction warnign light appeared instead
    if anyone can shed any light on the situation, either about the reapir, fault or where i stand with the insurance company i would really appreciate it
    thankyou
  2. Re: your opinions needed asap
    Oct 2007
    What was the fault code explanation for the steering angle sensor?
  3. Re: your opinions needed asap
    Jan 2008
    nottinghamshire
    Quote Originally Posted by kenney View Post
    the guy from the garage doesn't know the fault code, im presuming that they didnt plug it in with a vag com, but he has been told that the steering angle sencor on the steering wheel is at fault..
  4. Re: your opinions needed asap
    Oct 2007
    Somewhere along the line, someone must have read the fault memory,you can't just say the steering angle sensor is faulty,unless you know, you have destroyed it in some way or another.
  5. Re: your opinions needed asap
    Dec 2008
    Check that the brake light bulbs are functioning correctly. Take them out and re-seat them properly
    You might find this sorts the problem... good luck
    Ex - Allroad Tdi Limited Tipronic
    Now - A4 AVANT 1.9 TDI SPORT S-Line
  6. Re: your opinions needed asap
    Oct 2007
    What has the brake light bulbs to do with the steering angle sensor,think you got your posts mixed up
  7. Re: your opinions needed asap
    Dec 2008
    No mix up - maybe the garage mixed it up?
    Quote"hi the missis a4 had a accident, which had damaged the back 1/4 and the back wheel
    the car has been repaired but now there is a warnign light on, i think its the traction control light"
    traction control ESP warning light can be affected by dodgy brake light connection or bulb
  8. Re: your opinions needed asap
    Jan 2008
    nottinghamshire
    i know from what i can figure out they didnt use a vag com
    i asked for a fault code but i dont think they have one
    they just said the steering sencor was at fault, theres something not right at all, i wonder if its anything to do with the repair cause theve swapped the quarter panel so at some point the car has been stripped to complete bits, i knew there would be problems when they mentioned just car clinic, i asked if i could take it to a dealer but there was no other choice
    i dont think the steering wheel has removed from the car so i dont know how theyve broke that if it is that
  1. Help Needed Asap P/steering Belt Removal
    By andy51086 in forum The Commercial Range
    Last Post: 29-03-2008, 04:25 PM
  2. help Needed Asap!
    By SHAZA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-03-2008, 06:28 PM
  3. boost gauge guru needed asap!!!
    By gti power in forum Archive posts
    Last Post: 06-02-2008, 06:43 PM
  4. Honest Opinions needed!!!
    By phil1972 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-02-2008, 01:59 PM
  5. Opinions needed.
    By 1staudiA3 in forum Audi A3 - Archive Topics
    Last Post: 18-09-2007, 05:41 PM
