Thread: A4 1.9 TDI 03 engine not warming up.
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. Re: A4 1.9 TDI 03 engine not warming up.
    #21
    Mar 2014
    London
    No, fans operated correctly for me. I am talking about the thermostat housing. It's around £10 from Audi. Thermostat is around £40 from Audi too.
    The problem I think is when you take the old stat off to replace it, the housing tabs tend to break. So change the housing as well.
    If your fans are working all the time, might be related to CTS.
  2. Re: A4 1.9 TDI 03 engine not warming up.
    #22
    Apr 2016
    West Midlands
    Ok, cheers. I'm going to have to leave it till the weekend before I can get to a garage. Bit apprehensive about having to drive it up and down the motorway till then. Was a bit of a shock when it died on me today!
  3. Re: A4 1.9 TDI 03 engine not warming up.
    #23
    Apr 2016
    West Midlands
    Another issue! The ABS and ESP lights came on during the trip home. Drove ok but wasn't sure if id have another power loss. Made it home, did a little research and it appears to be the break light switch which is causing those lights to come on. Is it OK to drive with those lights on tonight and get it fixed tomorrow?
  4. Re: A4 1.9 TDI 03 engine not warming up.
    #24
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Think it's more likely to be an ABS sensor or cable than the switch, how did you reckon it might be the switch? You won't have functioning ABS while the light is on.
  5. Re: A4 1.9 TDI 03 engine not warming up.
    #25
    Apr 2016
    West Midlands
    Googled it. Turn ignition off and it clears the lights. Can make it happen again by pressing the brake pedal.
  6. Re: A4 1.9 TDI 03 engine not warming up.
    #26
    Nov 2010
    104 Post(s)
    fair enough - I've had to do a pedal switch on the touran and polo, seems to be a common enough failure but cheap fix.
  7. Re: A4 1.9 TDI 03 engine not warming up.
    #27
    Apr 2016
    West Midlands
    So if it's the brake pedal switch can I drive it? Only reason I ask is my daughter is currently at a concert 30 odd miles away and I was supposed to pick her up, might be a taxi instead!
  8. Re: A4 1.9 TDI 03 engine not warming up.
    #28
    Nov 2010
    104 Post(s)
    Sorry bud, can't answer that one for you , your call.
    If it was me though, and I was confident it was the switch and everything else was ok brake wise, I probably would.
    Does that cover my **** enough ???
  9. Re: A4 1.9 TDI 03 engine not warming up.
    #29
    Apr 2016
    West Midlands
    Fair enough mate. I'm probably not going to risk it. Knowing how things are going at the moment, it'd only break down on me!
  10. Re: A4 1.9 TDI 03 engine not warming up.
    #30
    Apr 2016
    West Midlands
    Got some codes.
    P1586 left/ right hydrolic sensor
    00526 brake switch
    Garage want £580 Inc labour for the hydraulic sensors. Said they can't just replace those, it's a whole unit. I'm not convinced so going to a different garage tomorrow. I still think it's the brake pedal switch.
  1. Engine warming before a cruise
    By Gabbatek in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 19-03-2011, 09:48 PM
  2. A4 Heater not warming up.
    By Caterham Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-03-2009, 10:40 PM
  3. Please Help Please please help - heating not warming up!!
    By kgowers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2008, 10:02 AM
  4. Engine not warming in cold
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-02-2008, 11:58 AM
  5. Engine vibration when warming up gt tdi
    By Vdubba in forum Archive posts
    Last Post: 14-06-2007, 01:38 PM
