Thread: Intermittent Brake vacuum pump issue - 1.9tdi PD
  1. Re: Intermittent Brake vacuum pump issue - 1.9tdi PD
    Apr 2016
    Shrop
    Intermittently the pedal is very hard to push down. Most of the time it works perfectly fine. Do you think my assumption is off?
    Ive been looking online and I can only find one part, reckon its worth calling Audi for clarification?
  2. Re: Intermittent Brake vacuum pump issue - 1.9tdi PD
    Pembrokeshire
    22 Post(s)
    you could call audi. is your plenum chamber flooded, the area where the servo lives ? does the power ever drop off at the same time as the hard pedal ? all you do now is attach a vacuum guage to the vac line and drive. it should pull 20 '' hg all the time. if it does the pumps ok, if not you need a new one, but chances are its the servo or a vac leak.
  3. Re: Intermittent Brake vacuum pump issue - 1.9tdi PD
    Apr 2016
    Shrop
    I'll check it out tomorrow and report back. My dads borrowed it for the past week so im sorta going by what he's said.
    Thanks for the advice.
  1. Brake vacuum pump failure?
    By stringman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-07-2015, 11:19 PM
  2. Replacement brake vacuum pump?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2011, 01:30 PM
  3. Question Low Turbo / Heavy Brake - Vacuum Issue?
    By themuttons in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2011, 03:02 PM
  4. Question How can you test a 1994 mk3 Golf td brake servo or vacuum pump
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-08-2009, 08:03 PM
  5. Brake fade. possible vacuum pump
    By dubstar81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2008, 06:28 PM
