Thread: clock failure
Results 1 to 10 of 12
  1. clock failure
    Apr 2011
    gillingham kent uk
    My Clocks have failed on my A8 (D3 4.2 '53 plate). I sent them off as there was no ignition (apparently clock problems are a known trait of Audi) and they have come back un repaired as their processor has totally burnt out. can anyone advise me of my options. I have been told that a new set of clocks will be needed as opposed to second hand/refurbished ones because the clocks complete with the car have to be taken to an Audi dealer who for a fee (£175 approx) will plug them into Germany who will code them to the car and put the correct mileage on them. Is there another way????.
  2. Re: clock failure
    Pembrokeshire
    22 Post(s)
    if you can find some clocks with the same part number, then find someone with either autologic or vag tacho, they may be able to get the skc code out of the old clocks and get it all working. you won't find a dealer who will code in used clocks though, only new clocks.
  3. Re: clock failure
    Apr 2011
    gillingham kent uk
    thanks zollaf I suppose then the next question will be. Is there anyone in the Kent area who has Autologic or vag tacho who can help me?
  4. Re: clock failure
    Pembrokeshire
    22 Post(s)
    your best bet is to do what i did. call the local dealer and ask them where they send the cars they cant fix. if they wont tell you then get on the blower and ask some local garages. eventually you will find that one bloke who works out of a shed or from the back of a van who can do anything with a computer.
  5. Re: clock failure
    Jun 2006
    UK, Mids
    There is no SKC on the D3 and later models but you buy used clocks and the DIS and speedo are disabled as an antitheft measure called Component Protection.
    The dealer may refuse to remove it (mine did on 'ethical' grounds!)
    I used Diagnostic equipment of Audi VW Specialists Centre in London who did it for a cheap price in 15 mins with the official Audi equipment and the required online decryption service to Gecko at Audi HQ.
    I used later clocks for a 2008 model (mine is 2006) and got them with the Wide DIS screen.
    The mileage is even harder to correct and the above company didn't want to do it.
    Audi A8 - 2015 - 3.0TDI
    2 2 0
  6. Re: clock failure
    Apr 2011
    gillingham kent uk
    thanks snapdragon, did you manage to get the mileage changed?
  7. Re: clock failure
    Jun 2006
    UK, Mids
    Not yet, I really should as it is >180,000 higher than it shows, the tool is ~£90 on aliexpress, so I would do that, the people who do it for you all seem too dodgy and charge ~£50 anyway.
    1 1 0
  8. Re: clock failure
    Apr 2011
    gillingham kent uk
    I have actually got the SUPER VAG K+CAN V4.8.1, that will do the job...I think. Thanks for your help Zollaf and snapdragon
  9. Re: clock failure
    Jan 2010
    Northants
    Hi Kergan, I have just had exactly the same problem happen to mine. Where did you send your unit for repair, as I would like to try a repair before a full replacement. If any others have any recommendations I would be glad to hear them??
    Thanks!
  10. Re: clock failure
    Apr 2011
    gillingham kent uk
    http://www.bba-reman.com/catalogue/D...edProduct=2262 have a look here. The guy I asked for help from sent my clocks off but I don't know the name of the company. The link have included is the company I was going to use. when your clocks failed did the whole lot fail, clocks, dis and warning lights?
  1. Water Pump Failure / Cam belts failure
    By Fly100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2014, 11:36 AM
  2. Please Help Odomoter & Clock failure
    By philhawthorn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2010, 04:00 PM
  3. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
  4. a3 clock
    By A3dude in forum Audi A3 - Archive Topics
    Last Post: 26-12-2007, 07:54 PM
  5. Clock
    By 1staudiA3 in forum Audi A3 - Archive Topics
    Last Post: 29-10-2007, 11:08 PM
