Thread: No power to the ECU
Page 13 of 13 FirstFirst ... 3111213
Results 121 to 129 of 129
  1. Re: No power to the ECU
    Feb 2025
    Newent, Gloucestershire
    Any clues as to how to remove this style of ECU plug?
    Sent from my M2101K6G using Tapatalk
  2. Re: No power to the ECU
    Feb 2025
    Here's a vid of my dashboard lights
    - YouTube
    Strangely, whilst trying to work out what's wrong, I've actually had it turn over on 2 occasions but not start, start on one occasion - then cut out after 30-40 seconds, now I just get the lights as shown. I've checked the '100' relay and that operates (as far as I know) correctly and I get different dash lights if it is not in circuit.
  3. Re: No power to the ECU
    Feb 2025
    I've managed to get my ECU plug off / out (cut slots in the anti tamper screws than used an impact driver to loosen them before unscrewing and slightly bending the plate to be able to remove it). have 'pluged and removed' a few times to try and help clean any terminals etc - still no joy starting but I don't have the flashing lights on ign on, I now get:
    But this was also how I saw the lights this morning before I tried anything, so I'm 99% sure it is not connected with me removing the ECU.
    I've also done another scan and I get (amongst others) Address 01: Engine Cannot be reached and Address 19: CAN Gateway (J533) 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication
    So do I need to dig into my central console and start checking the CAN module / plug / wires? I believe it is behind the Air con controls / and or radio area.
  4. Re: No power to the ECU
    135 Post(s)
    2026 Post(s)
    I have your VIN from your PM, can you post a full scan from VCDS as a .txt file?
  5. Re: No power to the ECU
    Feb 2025
    Many thanks Crusher - much appreciated!
    I'm not quote sure how to post it as a .txt file , so here's a copy/paste from that file. This was from before I disconnected / removed the ECU
    Code:
    Chassis Type: 3C-VW46 (7N0)Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62 65 69 72 01-Engine -- Status: Malfunction 1110 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 69-Trailer -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3AA-614-109.clb Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP Component: J104 C2 450M V40A 0030 Revision: --H07--- Serial number: 00000007626894 Coding: 0002992 Shop #: WSC 05311 000 00000 VCID: 7BF542EB3AE5695797-802E 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3AA 907 044 BT HW: 3AA 907 044 BT Component: Climatronic H05 0505 Revision: 00001K02 Coding: 061400C803 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_VW36.rod (VIN: N/A) VCID: 03053A0B8A151197DF-8056 1 Fault Found: 13701376 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb Part No SW: 3AA 937 087 P HW: 3AA 937 087 P Component: BCM PQ47 H 422 0474 Revision: BB422001 Coding: 0008000000000000009800805400816403510088426D87606480C7200041 Shop #: WSC 05311 000 00000 VCID: 479DEE1BF6ADFDB743-8012 Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB Component: Wischer 30101 26 0612 Coding: 00B795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 311013 05 54 0403 Coding: 2230ED 3 Faults Found: 00833 - Signal for Activation of Heated Windshield 009 - Open or Short to Ground - Intermittent 01314 - Engine Control Module 004 - No Signal/Communication 03678 - Coordinator for Start-Stop Operation 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb Part No SW: 3AE 919 475 C HW: 7N0 919 475 Component: PARKHILFE 8K H06 0018 Revision: -------- Serial number: 28231329103692 Coding: 118002 Shop #: WSC 99999 1023 2097151 ASAM Dataset: EV_EPHVA18VW47X0000 001006 ROD: EV_EPHVA18VW47X0000.rod (VIN: N/A) VCID: 3F8DF6FBA67DB577FB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA Component: J234__108 VW10 HI 2518 Revision: 27019000 Serial number: 003L7PP2DZHJ Coding: 0012344 Shop #: WSC 05311 000 00000 VCID: 7CF741F73FEB6E6F9E-8028 Subsystem 1 - Serial number: 6332MTS617962873 Subsystem 2 - Serial number: 6342MTS609662873 Subsystem 3 - Serial number: 6351HTS6JLLRECKR Subsystem 4 - Serial number: 6361HTS69AJIFCKJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20131008201503 Coding: 118A250000 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod (VIN: N/A) VCID: 76E353DFC9C7343FE8-8022 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB Component: E221__MFL-TK6 H07 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3AA 920 980 N HW: 3AA 920 980 N Component: KOMBI H04 0611 Serial number: 00000000000000 Coding: 461F00 Shop #: WSC 05314 115 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod (VIN: N/A) VCID: 3F8DF6FBA67DB577FB-806A 1 Fault Found: 12648448 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN Component: J533 Gateway H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 462007 Shop #: WSC 05314 000 00000 VCID: 7CF741F7FFEB6E6F9E-8028 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: IMMO 043 0407 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665337526 Coding: 020100 Shop #: WSC 05314 000 00000 VCID: 2B55B2AB4A0539D747-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 3C8 035 279 G HW: 3C8 035 279 G Component: RNS315-EU H76 0410 Serial number: VWZAZ2N0601260 Coding: 040004010400110000011002 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_RNS315EUV2UDS 001705 ROD: EV_RNS315EUV2UDS.rod VCID: 2F6DA6BB761D45F76B-807A Data carrier: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_V12 0078 1 Fault Found: 1048598 - Front Right Treble Speaker B1064 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 701 A HW: 3C0 959 793 C Component: TUER-SG FT 002 0534 Revision: 12110009 Serial number: 0007695044 Coding: 0212B7 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 ROD: EV_TSGFPQ35BRFVW46X_VW32.rod VCID: 356194D394417F2721-8060 Slave Driver: Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0503 Serial number: 00000003720677 Coding: 010290 1 Fault Found: 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 195 3501 Revision: 00H22000 Shop #: WSC 02069 000 90108 VCID: 397998E370599B47C5-806C 2 Faults Found: 03803 - Steering Angle Sensor for Steering Aid 000 - - - MIL ON 01314 - Engine Control Module 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: KSG PQ47 ELV 043 0645 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 0191020052830E76340C94157C085FCE105C04 Shop #: WSC 05311 000 00000 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AN Component: EZE_2 H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 050B0508 Shop #: WSC 05314 000 00000 VCID: 6FED66BBBE9D05F72B-803A Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J245EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J394EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A Component: Analoguhr 004 0004 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 702 A HW: 3C0 959 792 C Component: TUER-SG BT 002 0534 Revision: 14110009 Serial number: 0007704561 Coding: 0212B6 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 ROD: EV_TSGBPQ35BRFVW46X_VW32.rod VCID: 366393DF8947743F28-8062 Slave Passenger: Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0503 Serial number: 00000003721958 Coding: 010290 1 Fault Found: 68108 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 H HW: 3AA 907 801 H Component: J540 EPB4 VW-86594 0010 Revision: H19 Serial number: 00000001606578 Coding: 0022167 Shop #: WSC 05311 000 00000 VCID: 366393DF4147743F28-8062 4 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication 03182 - Clutch Position Sensor (G476) 010 - Open or Short to Plus - Intermittent 01314 - Engine Control Module 008 - Implausible Signal 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 7N0 907 530 AN Component: Batt.regelung H56 1642 Serial number: 131013F2000903 Coding: 330F1859 Shop #: WSC 05314 000 00000 VCID: 71E960C3A8A913073D-8024 Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A Component: J367-BDM H07 0180 Serial number: 40304F47221491365162 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 D HW: 3AA 907 273 D Component: RDKBERU30 H09 0010 Serial number: 30000000008106 ASAM Dataset: EV_RDKBERU30 003012 ROD: EV_RDKBERU30_003.rod VCID: 356194D394417F2721-8060 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 7N0-907-383.clb Part No SW: 7N0 907 383 HW: 7N0 907 383 Component: Anhaenger H09 0120 Revision: 3I001003 Serial number: 00008160140260 Coding: 4106040001000000 Shop #: WSC 05314 000 00000 VCID: 73E56ACBD2B52117CF-8026 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication 00532 - Supply Voltage B+ 011 - Open Circuit - Intermittent - MIL ON End---------------------(Elapsed Time: 04:11, udsna)-----------------------
  6. Re: No power to the ECU
    Feb 2025
    I was also going to add a current video of my startup lights but YouTube isn't playing ball at the moment.....
    I'll keep trying.
    It's still not playing ball so here's a picture of the 'steady state', once the start-up routine has completed - about 13 seconds after key in.
    Finally - YouTube is playing ball - https://youtu.be/wCHAhwwJyWY
  7. Re: No power to the ECU
    Feb 2025
    A new day - same car - different results! Arrgh!
    I left it yesterday with the dash lights and readout as per my post above.
    Tried it again a short while ago - I thought I'd just see what I'm getting today. VCDS was already plugged in, so I attempted a start - it started! Whaaat?? Let it idle for a few mins, revved it up to 2500rpm (it wouldn't rev above 2500rpm). Whilst it was running, ran VCDS full test. Found faults, cleared them, ran a second test, found fewer faults, cleared them (but obviously failed to record this in the log). stopped engine - tried a restart - it restarted (still no rev above 2500rpm).
    Stopped the engine and did another fault code clear and another full sweep. Disconnected VCDS, tried another restart - restarted fine, no dash lights. I haven't driven it anywhere as I currently have no confidence in it - so as far as I'm concerned, it is still 'broken' as I haven't actually changed anything and other than plugging / unplugging a few items, nothing has changed (except outside temp - but I didn't have any issues when it was around -2 C a few weeks ago).
    VCDS as follows:
    Also - as seen in the 1st bit of readout - it shows 1205 rpm but speed at 60km/h!!! I was sat stationary on my drive.
    Code:
    Friday,21,February,2025,16:08:43:00009 Mileage: 207140km-128710mi Repair Order: 292592211608 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C-VW46 (01 - WD63OPT) Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62 65 69 72 VIN: Mileage: 207140km-128710miles ------------------------------------------------------------------------------- Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 PR HW: 03L 907 309 AE Component: R4 2,0L EDC X28 4006 Revision: 41X28--- Serial number: 00000000000000 CVN: DE61F492 Coding: 00190012043501080000 Shop #: WSC 92521 052 00000 ASAM Dataset: EV_ECM20TDI01103L906018PR 003004 ROD: EV_ECM20TDI01103L906018PR.rod VCID: 09192823A8394BC795-805C VINID: 9E69EAAAA0D3A95540204046043A8F1A88 5 Faults Found: 4481 - Cruise Control Switch (E45) P0568 00 [032] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206707 km Date: 2125.14.19 Time: 11:01:38 Engine RPM: 1205.50 /min Normed load value: 0.0 % Vehicle speed: 60 km/h Coolant temperature: 77 °C Intake air temperature: 10 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.940 V Unlearning counter according OBD: 29 Cruise Control System (CCS): switch position-Bits 0-7: 128 Cruise Control System (CCS): status-Bits 0-7: 8 Cruise control switch-off: irreversible-Bits 0-7: 255 Cruise control switch-off: reversible-Bits 0-7: 7 Cruise Control System: specified speed: 0.00 km/h Engine control module reset status-Bits 0-7: 0 Engine control module reset status-Bits 0-7: 0 Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0 4483 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 206707 km Date: 2125.14.19 Time: 11:01:38 Engine RPM: 1204.00 /min Normed load value: 0.0 % Vehicle speed: 59 km/h Coolant temperature: 77 °C Intake air temperature: 9 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.960 V Unlearning counter according OBD: 29 Cruise Control System (CCS): switch position-Bits 0-7: 192 Cruise Control System (CCS): status-Bits 0-7: 200 Cruise control switch-off: irreversible-Bits 0-7: 0 Cruise control switch-off: reversible-Bits 0-7: 7 Cruise Control System: specified speed: 0.00 km/h Engine control module reset status-Bits 0-7: 0 Engine control module reset status-Bits 0-7: 0 Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1 5174 - Fuel Pressure Regulation P1065 00 [096] - Regulation Discrepancy Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 207037 km Date: 2127.14.06 Time: 11:38:38 Engine RPM: 1252.50 /min Normed load value: 62.0 % Vehicle speed: 49 km/h Coolant temperature: 50 °C Intake air temperature: 5 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 14.700 V Unlearning counter according OBD: 37 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 4629 - ECM Power Relay Load Circuit P068A 00 [032] - Opens Too Early Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: -40 °C Intake air temperature: -40 °C Ambient air pressure: 0 mbar Voltage terminal 30: 0.000 V Unlearning counter according OBD: 40 Accelerator pedal travel: 0.00 % Starter control: Interlock- or P/N-signal-Bits 0-7: 0 Engine status: COENG_STANDBY Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0 4611 - Control Module Malfunction - DBW Throttle Monitoring P1388 00 [167] - - MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Date: 2000.00.00 Time: 00:00:00 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 29 °C Intake air temperature: 13 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.460 V Unlearning counter according OBD: 40 Speed regulation requested torque: 1207.7 Nm Accelerator pedal travel: 0.00 % Accelerator pedal: sensor voltage 1: 752.4 mV Accelerator pedal: sensor voltage 2: 381.0 mV Control Module temperature: 6.4 °C Outside temperature: 13.0 °C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3AA-614-109.clb Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP Component: J104 C2 450M V40A 0030 Revision: --H07--- Serial number: 00000007626894 Coding: 0002992 Shop #: WSC 05311 000 00000 VCID: 7BF542EB3AE5695797-802E 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 26 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 23:03:53 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 11.25 V Bin. Bits: 00011111 Count: 220 Hex Value: 0x0000 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 26 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 23:03:53 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 11.25 V Bin. Bits: 00011111 Count: 220 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3AA 907 044 BT HW: 3AA 907 044 BT Component: Climatronic H05 0505 Revision: 00001K02 Coding: 061400C803 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_VW46.rod VCID: 03053A0B8A151197DF-8056 1 Fault Found: 13701376 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 10 Reset counter: 50 Mileage: 207141 km Date: 2127.14.31 Time: 23:03:51 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb Part No SW: 3AA 937 087 P HW: 3AA 937 087 P Component: BCM PQ47 H 422 0474 Revision: BB422001 Coding: 0008000000000000009800805400816403510088426D87606480C7200041 Shop #: WSC 05311 000 00000 VCID: 479DEE1BF6ADFDB743-8012 Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB Component: Wischer 30101 26 0612 Coding: 00B795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 311013 05 54 0403 Coding: 2230ED 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 8 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 23:03:53 Freeze Frame: Term 15 On Voltage: 11.45 V ON ON ON OFF OFF 03678 - Coordinator for Start-Stop Operation 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 8 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 23:03:53 Freeze Frame: Term 15 On Voltage: 11.45 V ON ON ON OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb Part No SW: 3AE 919 475 C HW: 7N0 919 475 Component: PARKHILFE 8K H06 0018 Revision: -------- Serial number: 28231329103692 Coding: 118002 Shop #: WSC 99999 1023 2097151 ASAM Dataset: EV_EPHVA18VW47X0000 001006 ROD: EV_EPHVA18VW47X0000.rod VCID: 3F8DF6FBA67DB577FB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA Component: J234__108 VW10 HI 2518 Revision: 27019000 Serial number: 003L7PP2DZHJ Coding: 0012344 Shop #: WSC 05311 000 00000 VCID: 7CF741F73FEB6E6F9E-8028 Subsystem 1 - Serial number: 6332MTS617962873 Subsystem 2 - Serial number: 6342MTS609662873 Subsystem 3 - Serial number: 6351HTS6JLLRECKR Subsystem 4 - Serial number: 6361HTS69AJIFCKJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20131008201503 Coding: 118A250000 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 76E353DFC9C7343FE8-8022 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB Component: E221__MFL-TK6 H07 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3AA 920 980 N HW: 3AA 920 980 N Component: KOMBI H04 0611 Serial number: 00000000000000 Coding: 461F00 Shop #: WSC 05314 115 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod VCID: 3F8DF6FBA67DB577FB-806A 1 Fault Found: 12648448 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 16 Reset counter: 50 Mileage: 207141 km Date: 2025.02.21 Time: 23:03:51 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN Component: J533 Gateway H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 462007 Shop #: WSC 05314 000 00000 VCID: 7CF741F7FFEB6E6F9E-8028 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 18 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 23:03:53 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: IMMO 043 0407 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665337526 Coding: 020100 Shop #: WSC 05314 000 00000 VCID: 2B55B2AB4A0539D747-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 3C8 035 279 G HW: 3C8 035 279 G Component: RNS315-EU H76 0410 Serial number: VWZAZ2N0601260 Coding: 040004010400110000011002 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_RNS315EUV2UDS 001705 ROD: EV_RNS315EUV2UDS.rod VCID: 2F6DA6BB761D45F76B-807A Data carrier: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_V12 0078 1 Fault Found: 1048598 - Front Right Treble Speaker B1064 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 10 Mileage: 207141 km Date: 2025.02.21 Time: 23:03:54 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 701 A HW: 3C0 959 793 C Component: TUER-SG FT 002 0534 Revision: 12110009 Serial number: 0007695044 Coding: 0212B7 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 ROD: EV_TSGFPQ35BRFVW46X_VW32.rod VCID: 356194D394417F2721-8060 Slave Driver: Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0503 Serial number: 00000003720677 Coding: 010290 1 Fault Found: 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 50 Mileage: 207141 km Date: 2025.02.21 Time: 00:00:45 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 195 3501 Revision: 00H22000 Shop #: WSC 02069 000 90108 VCID: 397998E370599B47C5-806C 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 6 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 00:00:49 Freeze Frame: Voltage: 12.38 V DU Temperature: 14.0°C RPM: 1498 /min Speed: 0.0 km/h Speed: 0.0 km/h Count: 0 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: KSG PQ47 ELV 043 0645 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 0191020052830E76340C94157C085FCE105C04 Shop #: WSC 05311 000 00000 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AN Component: EZE_2 H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 050B0508 Shop #: WSC 05314 000 00000 VCID: 6FED66BBBE9D05F72B-803A Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J245EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J394EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A Component: Analoguhr 004 0004 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 702 A HW: 3C0 959 792 C Component: TUER-SG BT 002 0534 Revision: 14110009 Serial number: 0007704561 Coding: 0212B6 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 ROD: EV_TSGBPQ35BRFVW46X_VW32.rod VCID: 366393DF8947743F28-8062 Slave Passenger: Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0503 Serial number: 00000003721958 Coding: 010290 1 Fault Found: 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 50 Mileage: 207141 km Date: 2025.02.21 Time: 00:00:45 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 H HW: 3AA 907 801 H Component: J540 EPB4 VW-86594 0010 Revision: H19 Serial number: 00000001606578 Coding: 0022167 Shop #: WSC 05311 000 00000 VCID: 366393DF4147743F28-8062 4 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 41 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 15:15:26 Freeze Frame: Voltage: 11.20 V Count: 71 Speed: 0.0 km/h Hex Value: 0x1263 Hex Value: 0x0001 Hex Value: 0x1010 03182 - Clutch Position Sensor (G476) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 50 Time Indication: 0 Freeze Frame: Voltage: 11.90 V Count: 55 Speed: 0.0 km/h Hex Value: 0x1273 Hex Value: 0x0001 Hex Value: 0x1010 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01111101 Fault Priority: 2 Fault Frequency: 5 Reset counter: 10 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 00:00:28 Freeze Frame: Voltage: 11.70 V Count: 65 Speed: 0.0 km/h Hex Value: 0x1273 Hex Value: 0x0001 Hex Value: 0x1010 01314 - Engine Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 00:00:31 Freeze Frame: Voltage: 11.80 V Count: 61 Speed: 0.0 km/h Hex Value: 0x1273 Hex Value: 0x0001 Hex Value: 0x1010 ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 7N0 907 530 AN Component: Batt.regelung H56 1642 Serial number: 131013F2000903 Coding: 330F1859 Shop #: WSC 05314 000 00000 VCID: 71E960C3A8A913073D-8024 Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A Component: J367-BDM H07 0180 Serial number: 40304F47221491365162 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 D HW: 3AA 907 273 D Component: RDKBERU30 H09 0010 Serial number: 30000000008106 ASAM Dataset: EV_RDKBERU30 003012 ROD: EV_RDKBERU30_003.rod VCID: 356194D394417F2721-8060 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 7N0-907-383.clb Part No SW: 7N0 907 383 HW: 7N0 907 383 Component: Anhaenger H09 0120 Revision: 3I001003 Serial number: 00008160140260 Coding: 4106040001000000 Shop #: WSC 05314 000 00000 VCID: 73E56ACBD2B52117CF-8026 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 26 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 15:15:27 End-------------------------(Elapsed Time: 04:09)-------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 44: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 03: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 03: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C-VW46 Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62 65 69 72 VIN: Mileage: 207140km-128710miles ------------------------------------------------------------------------------- Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 PR HW: 03L 907 309 AE Component: R4 2,0L EDC X28 4006 Revision: 41X28--- Serial number: 00000000000000 CVN: DE61F492 Coding: 00190012043501080000 Shop #: WSC 92521 052 00000 ASAM Dataset: EV_ECM20TDI01103L906018PR 003004 ROD: EV_ECM20TDI01103L906018PR.rod VCID: 09192823A8394BC795-805C VINID: 9E69EAAAA0D3A95540204046043A8F1A88 1 Fault Found: 4611 - Control Module Malfunction - DBW Throttle Monitoring P1388 00 [036] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 207141 km Date: 2127.14.31 Time: 16:10:49 Engine RPM: 1200.00 /min Normed load value: 19.6 % Vehicle speed: 0 km/h Coolant temperature: 53 °C Intake air temperature: 21 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.600 V Unlearning counter according OBD: 40 Speed regulation requested torque: -447.2 Nm Accelerator pedal travel: 0.00 % Accelerator pedal: sensor voltage 1: 0.0 mV Accelerator pedal: sensor voltage 2: 0.0 mV Control Module temperature: 11.8 °C Outside temperature: 13.5 °C Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3AA-614-109.clb Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP Component: J104 C2 450M V40A 0030 Revision: --H07--- Serial number: 00000007626894 Coding: 0002992 Shop #: WSC 05311 000 00000 VCID: 7BF542EB3AE5695797-802E 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 16:11:30 Freeze Frame: Speed: 0.0 km/h Hex Value: 0x0000 Bin. Bits: 00000000 00000000 Voltage: 12.50 V Bin. Bits: 00011111 Count: 229 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3AA 907 044 BT HW: 3AA 907 044 BT Component: Climatronic H05 0505 Revision: 00001K02 Coding: 061400C803 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_VW46.rod VCID: 03053A0B8A151197DF-8056 1 Fault Found: 13701376 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 10 Reset counter: 50 Mileage: 207141 km Date: 2127.14.31 Time: 23:03:51 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb Part No SW: 3AA 937 087 P HW: 3AA 937 087 P Component: BCM PQ47 H 422 0474 Revision: BB422001 Coding: 0008000000000000009800805400816403510088426D87606480C7200041 Shop #: WSC 05311 000 00000 VCID: 479DEE1BF6ADFDB743-8012 Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB Component: Wischer 30101 26 0612 Coding: 00B795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 311013 05 54 0403 Coding: 2230ED 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 8 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 23:03:53 Freeze Frame: Term 15 On Voltage: 11.45 V ON ON ON OFF OFF 03678 - Coordinator for Start-Stop Operation 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 8 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2063.14.31 Time: 23:03:53 Freeze Frame: Term 15 On Voltage: 11.45 V ON ON ON OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb Part No SW: 3AE 919 475 C HW: 7N0 919 475 Component: PARKHILFE 8K H06 0018 Revision: -------- Serial number: 28231329103692 Coding: 118002 Shop #: WSC 99999 1023 2097151 ASAM Dataset: EV_EPHVA18VW47X0000 001006 ROD: EV_EPHVA18VW47X0000.rod VCID: 3F8DF6FBA67DB577FB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA Component: J234__108 VW10 HI 2518 Revision: 27019000 Serial number: 003L7PP2DZHJ Coding: 0012344 Shop #: WSC 05311 000 00000 VCID: 7CF741F73FEB6E6F9E-8028 Subsystem 1 - Serial number: 6332MTS617962873 Subsystem 2 - Serial number: 6342MTS609662873 Subsystem 3 - Serial number: 6351HTS6JLLRECKR Subsystem 4 - Serial number: 6361HTS69AJIFCKJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20131008201503 Coding: 118A250000 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 76E353DFC9C7343FE8-8022 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB Component: E221__MFL-TK6 H07 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3AA 920 980 N HW: 3AA 920 980 N Component: KOMBI H04 0611 Serial number: 00000000000000 Coding: 461F00 Shop #: WSC 05314 115 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod VCID: 3F8DF6FBA67DB577FB-806A 1 Fault Found: 12648448 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 16 Reset counter: 50 Mileage: 207141 km Date: 2025.02.21 Time: 23:03:51 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN Component: J533 Gateway H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 462007 Shop #: WSC 05314 000 00000 VCID: 7CF741F7FFEB6E6F9E-8028 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 18 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 23:03:53 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: IMMO 043 0407 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665337526 Coding: 020100 Shop #: WSC 05314 000 00000 VCID: 2B55B2AB4A0539D747-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 3C8 035 279 G HW: 3C8 035 279 G Component: RNS315-EU H76 0410 Serial number: VWZAZ2N0601260 Coding: 040004010400110000011002 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_RNS315EUV2UDS 001705 ROD: EV_RNS315EUV2UDS.rod VCID: 2F6DA6BB761D45F76B-807A Data carrier: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_V12 0078 1 Fault Found: 1048598 - Front Right Treble Speaker B1064 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 10 Mileage: 207141 km Date: 2025.02.21 Time: 23:03:54 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 701 A HW: 3C0 959 793 C Component: TUER-SG FT 002 0534 Revision: 12110009 Serial number: 0007695044 Coding: 0212B7 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 ROD: EV_TSGFPQ35BRFVW46X_VW32.rod VCID: 356194D394417F2721-8060 Slave Driver: Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0503 Serial number: 00000003720677 Coding: 010290 1 Fault Found: 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 50 Mileage: 207141 km Date: 2025.02.21 Time: 00:00:45 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 195 3501 Revision: 00H22000 Shop #: WSC 02069 000 90108 VCID: 397998E370599B47C5-806C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: KSG PQ47 ELV 043 0645 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 0191020052830E76340C94157C085FCE105C04 Shop #: WSC 05311 000 00000 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AN Component: EZE_2 H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 050B0508 Shop #: WSC 05314 000 00000 VCID: 6FED66BBBE9D05F72B-803A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 702 A HW: 3C0 959 792 C Component: TUER-SG BT 002 0534 Revision: 14110009 Serial number: 0007704561 Coding: 0212B6 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 ROD: EV_TSGBPQ35BRFVW46X_VW32.rod VCID: 366393DF8947743F28-8062 Slave Passenger: Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0503 Serial number: 00000003721958 Coding: 010290 1 Fault Found: 68108 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 50 Mileage: 207141 km Date: 2025.02.21 Time: 00:00:45 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 H HW: 3AA 907 801 H Component: J540 EPB4 VW-86594 0010 Revision: H19 Serial number: 00000001606578 Coding: 0022167 Shop #: WSC 05311 000 00000 VCID: 366393DF4147743F28-8062 4 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 41 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 15:15:26 Freeze Frame: Voltage: 11.20 V Count: 71 Speed: 0.0 km/h Hex Value: 0x1263 Hex Value: 0x0001 Hex Value: 0x1010 03182 - Clutch Position Sensor (G476) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 50 Time Indication: 0 Freeze Frame: Voltage: 11.90 V Count: 55 Speed: 0.0 km/h Hex Value: 0x1273 Hex Value: 0x0001 Hex Value: 0x1010 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 2 Fault Frequency: 5 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 00:00:28 Freeze Frame: Voltage: 11.70 V Count: 65 Speed: 0.0 km/h Hex Value: 0x1273 Hex Value: 0x0001 Hex Value: 0x1010 01314 - Engine Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 00:00:31 Freeze Frame: Voltage: 11.80 V Count: 61 Speed: 0.0 km/h Hex Value: 0x1273 Hex Value: 0x0001 Hex Value: 0x1010 ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 7N0 907 530 AN Component: Batt.regelung H56 1642 Serial number: 131013F2000903 Coding: 330F1859 Shop #: WSC 05314 000 00000 VCID: 71E960C3A8A913073D-8024 Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A Component: J367-BDM H07 0180 Serial number: 40304F47221491365162 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 D HW: 3AA 907 273 D Component: RDKBERU30 H09 0010 Serial number: 30000000008106 ASAM Dataset: EV_RDKBERU30 003012 ROD: EV_RDKBERU30_003.rod VCID: 356194D394417F2721-8060 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 7N0-907-383.clb Part No SW: 7N0 907 383 HW: 7N0 907 383 Component: Anhaenger H09 0120 Revision: 3I001003 Serial number: 00008160140260 Coding: 4106040001000000 Shop #: WSC 05314 000 00000 VCID: 73E56ACBD2B52117CF-8026 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 26 Reset counter: 50 Mileage: 207141 km Time Indication: 0 Date: 2019.07.15 Time: 15:15:27 End-------------------------(Elapsed Time: 03:24)-------------------------- -------------------------------------------------------------------------------- Fault Codes cleared again at this point but I obviously forgot to save that info (or didn't realise it wouldn't be saved) Also, engine no longer running as I stopped it to see if I got different codes / results. -------------------------------------------------------------------------------- Gateway Installation List: 7N0 907 530 AN 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 69-Trailer -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C-VW46 Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62 65 69 72 VIN: Mileage: 207140km-128710miles ------------------------------------------------------------------------------- Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 PR HW: 03L 907 309 AE Component: R4 2,0L EDC X28 4006 Revision: 41X28--- Serial number: 00000000000000 CVN: DE61F492 Coding: 00190012043501080000 Shop #: WSC 92521 052 00000 ASAM Dataset: EV_ECM20TDI01103L906018PR 003004 ROD: EV_ECM20TDI01103L906018PR.rod VCID: 09192823A8394BC795-805C VINID: 9E69EAAAA0D3A95540204046043A8F1A88 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3AA-614-109.clb Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP Component: J104 C2 450M V40A 0030 Revision: --H07--- Serial number: 00000007626894 Coding: 0002992 Shop #: WSC 05311 000 00000 VCID: 7BF542EB3AE5695797-802E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3AA 907 044 BT HW: 3AA 907 044 BT Component: Climatronic H05 0505 Revision: 00001K02 Coding: 061400C803 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_VW46.rod VCID: 03053A0B8A151197DF-8056 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb Part No SW: 3AA 937 087 P HW: 3AA 937 087 P Component: BCM PQ47 H 422 0474 Revision: BB422001 Coding: 0008000000000000009800805400816403510088426D87606480C7200041 Shop #: WSC 05311 000 00000 VCID: 479DEE1BF6ADFDB743-8012 Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB Component: Wischer 30101 26 0612 Coding: 00B795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 311013 05 54 0403 Coding: 2230ED No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb Part No SW: 3AE 919 475 C HW: 7N0 919 475 Component: PARKHILFE 8K H06 0018 Revision: -------- Serial number: 28231329103692 Coding: 118002 Shop #: WSC 99999 1023 2097151 ASAM Dataset: EV_EPHVA18VW47X0000 001006 ROD: EV_EPHVA18VW47X0000.rod VCID: 3F8DF6FBA67DB577FB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA Component: J234__108 VW10 HI 2518 Revision: 27019000 Serial number: 003L7PP2DZHJ Coding: 0012344 Shop #: WSC 05311 000 00000 VCID: 7CF741F73FEB6E6F9E-8028 Subsystem 1 - Serial number: 6332MTS617962873 Subsystem 2 - Serial number: 6342MTS609662873 Subsystem 3 - Serial number: 6351HTS6JLLRECKR Subsystem 4 - Serial number: 6361HTS69AJIFCKJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB Component: LENKS.MODUL 016 0140 Revision: FF010042 Serial number: 20131008201503 Coding: 118A250000 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 76E353DFC9C7343FE8-8022 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB Component: E221__MFL-TK6 H07 0022 Coding: E20000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3AA 920 980 N HW: 3AA 920 980 N Component: KOMBI H04 0611 Serial number: 00000000000000 Coding: 461F00 Shop #: WSC 05314 115 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod VCID: 3F8DF6FBA67DB577FB-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN Component: J533 Gateway H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 462007 Shop #: WSC 05314 000 00000 VCID: 7CF741F7FFEB6E6F9E-8028 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: IMMO 043 0407 Revision: 00043000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665337526 Coding: 020100 Shop #: WSC 05314 000 00000 VCID: 2B55B2AB4A0539D747-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 3C8 035 279 G HW: 3C8 035 279 G Component: RNS315-EU H76 0410 Serial number: VWZAZ2N0601260 Coding: 040004010400110000011002 Shop #: WSC 00015 115 00000 ASAM Dataset: EV_RNS315EUV2UDS 001705 ROD: EV_RNS315EUV2UDS.rod VCID: 2F6DA6BB761D45F76B-807A Data carrier: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_V12 0078 1 Fault Found: 1048598 - Front Right Treble Speaker B1064 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 10 Mileage: 207141 km Date: 2025.02.21 Time: 16:16:38 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 701 A HW: 3C0 959 793 C Component: TUER-SG FT 002 0534 Revision: 12110009 Serial number: 0007695044 Coding: 0212B7 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 ROD: EV_TSGFPQ35BRFVW46X_VW32.rod VCID: 356194D394417F2721-8060 Slave Driver: Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB Component: J389__TSG-HR 004 0503 Serial number: 00000003720677 Coding: 010290 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 195 3501 Revision: 00H22000 Shop #: WSC 02069 000 90108 VCID: 397998E370599B47C5-806C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3AA 959 433 B HW: 3AA 959 433 B Component: KSG PQ47 ELV 043 0645 Revision: 00043000 Serial number: VWZCZ000000000 Coding: 0191020052830E76340C94157C085FCE105C04 Shop #: WSC 05311 000 00000 VCID: 387F9DE74B53824F3A-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AN Component: EZE_2 H56 1642 Revision: H56 Serial number: 131013F2000903 Coding: 050B0508 Shop #: WSC 05314 000 00000 VCID: 6FED66BBBE9D05F72B-803A Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J245EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J394EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A Component: Analoguhr 004 0004 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb Part No SW: 3AA 959 702 A HW: 3C0 959 792 C Component: TUER-SG BT 002 0534 Revision: 14110009 Serial number: 0007704561 Coding: 0212B6 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 ROD: EV_TSGBPQ35BRFVW46X_VW32.rod VCID: 366393DF8947743F28-8062 Slave Passenger: Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB Component: J388__TSG-HL 004 0503 Serial number: 00000003721958 Coding: 010290 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 H HW: 3AA 907 801 H Component: J540 EPB4 VW-86594 0010 Revision: H19 Serial number: 00000001606578 Coding: 0022167 Shop #: WSC 05311 000 00000 VCID: 366393DF4147743F28-8062 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 7N0 907 530 AN Component: Batt.regelung H56 1642 Serial number: 131013F2000903 Coding: 330F1859 Shop #: WSC 05314 000 00000 VCID: 71E960C3A8A913073D-8024 Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A Component: J367-BDM H07 0180 Serial number: 40304F47221491365162 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 D HW: 3AA 907 273 D Component: RDKBERU30 H09 0010 Serial number: 30000000008106 ASAM Dataset: EV_RDKBERU30 003012 ROD: EV_RDKBERU30_003.rod VCID: 356194D394417F2721-8060 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 7N0-907-383.clb Part No SW: 7N0 907 383 HW: 7N0 907 383 Component: Anhaenger H09 0120 Revision: 3I001003 Serial number: 00008160140260 Coding: 4106040001000000 Shop #: WSC 05314 000 00000 VCID: 73E56ACBD2B52117CF-8026 No fault code found. End-------------------------(Elapsed Time: 03:24)--------------------------
  8. Re: No power to the ECU
    135 Post(s)
    2026 Post(s)
    I,would start by replacing the 100 relay at position four with the revised 644 type, part number 4H0 951 253
  9. Re: No power to the ECU
    Feb 2025
    Newent, Gloucestershire
    Thanks, I'll get one on order.
    Today's Update: Without doing anything to my car since yesterday, I tried to start it - started fine, so after about 30-60 seconds, I stopped the engine and tried again - started fine. So then as I replaced items (ECU plug securing strap, ECU into 'fitted' position, battery cover, pretty much any item I had removed), I tried a re-start - and every time it started! I then went for a tentative drive -all seemed good (with one slight exception being my Cruise Control but that is not related to this fault) but I waited until I got home before stopping the engine once more, then tried restarting it again - yup, it started fine.
    So, nothing has been replaced, a few plugs / socket / wires have been jiggled and now it seems ok - but of course, confidence is slightly lacking at the moment....
    I'll start a new thread about my Cruise Control - it's a sticky switch, so nothing to do with any of this.
Page 13 of 13 FirstFirst ... 3111213
  1. Ecu power suply relay
    By juleshs1968 in forum Beetle 2000-
    Last Post: 29-04-2015, 11:36 PM
  2. ecu power upgrade/ swap for passat possible???
    By 930JON in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2010, 02:12 AM
  3. Question PLEASE HELP..is juddering and loss of power due to a recall on the ECU..?
    By aogriffith in forum Golf MK5 - 2004 - 2009
    Last Post: 10-03-2010, 11:03 AM
  4. Polo 1.9TDI S ECU Power steering?
    By colinayr in forum Polo - Derby - Lupo - Fox
    Last Post: 30-10-2008, 10:25 AM
  5. Question Location of ECU power relay
    By Unforgiven2 in forum Bora - 1998 - 2005
    Last Post: 08-10-2008, 09:48 PM
