Thread: HELP - AKE engine injector #3 with needle lift sensor needed
  1. HELP - AKE engine injector #3 with needle lift sensor needed
    Robnelson76 Guest
    Hi Folks,
    I have a 2002 A6 2.5tdi and after doing the Cambelt I've discovered that my needle lift sensor on injector #3 has given up the ghost and I can't adjust the timing without getting it sorted.
    Audi want over 25% of the car value for one, does anyone have a spare I can buy?
    Please help..... Please......
  2. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    Aug 2011
    Meath
  3. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    Jul 2011
    Norway
    Hi, try to adjust the pump so the readings in measuring blocks- cold start valve/ advance solenoid is around 95 % at idle ( engine temp over 85 degrees) The ECU uses a sensor in the Injection pump and the Engine speed sensor to figure this out,
    so you might get lucky...
  4. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    8 Post(s)
    ebay is the best bet.
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  5. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    Robnelson76 Guest
    Does anyone have any info on how easy it is to change Injector # 3? Now I have a shiny new one I'm thinking of swapping it myself.....?
    Thanks.
    Rob
  6. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    8 Post(s)
    It's fairly tricky to do but you only need to get the left side rocker cover off and you can see the injector to get it off. you need to strip a fair bit down though.
  7. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    Bonny Scotland
    Good guide here
    http://www.audi-sport.net/vb/a4-a4-c...placement.html
    I used this when swapping number 5 injector on my BDH. Before you start make sure you have a new rocker cover gasket, copper sealing washer for the injector (dealer, 51p) and new leak-off banjo copper sealing washers (21p, dealer). I wish I'd done my rocker cover gasket at the same time as it'll never seal again properly.
    Frank
  8. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    Apr 2015
    Hi
    I am looking for a replacement needle lift sensor part no. 059130202F for my Audi allroad 2.5 tdi car , 2004 model. can anyone help me out with this. thanks
  9. Re: HELP ---- AKE engine injector #3 with needle lift sensor needed
    8 Post(s)
    Quote Originally Posted by taggart View Post
    Hi
    I'd start on fleabay.
  1. Please Help diesel injector with needle lift sensor
    By chazcrute in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-03-2015, 10:04 AM
  2. Please Help A4 B6 2.5 TDI - Injector 3 (Needle Lift)
    By jamin128 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2015, 10:34 PM
  3. Question Need to replace injector 3 (needle lift sensor 80) 2.5 TDI V6, Have questions:
    By Ash3000k in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-10-2014, 10:51 AM
  4. Replies: 3
    Last Post: 26-10-2009, 11:51 AM
  5. Injector with the needle lift sensor
    By amac12 in forum Alhambra
    Last Post: 06-02-2008, 04:51 PM
