Thread: How to bleed a pd130 clutch help
Hybrid View
  1. How to bleed a pd130 clutch help
    Mar 2016
    West Malling
    Anyone on here help me??
    Anyone know how to bleed the clutch on a pd130 asz engine code
    Many thanks
  2. Re: How to bleed a pd130 clutch help
    Oct 2015
    GB
    You will need a tube and bottle, fill the bottle up an inch with dot4 fluid.
    You will also more than like need a pressure bleed kit (easibleed) too.
    Attach the bottle and tube to the clutch slave cylinder nipple,
    No connect your pressure bleed kit to the fluid resivour tank.
    Next crack open the bleed nipple and watch the bubbles flow down the clear tube, when the bubbles are gone close the nipple to allow the pressure to build up again, then crack it open one last time to double check all bubbles are gone.
    Now close the nipple, and job done.
    Just out of interest why are you bleeding the clucth?
    Sent from my SM-A300FU using Tapatalk
  3. Re: How to bleed a pd130 clutch help
    Oct 2015
    GB
    The old method is;
    Bottle and tube, fill it up with dot4 an inch.
    Attach to slave nipple, have someone to operate the peddle.
    So, peddle down nipple open until no bubbles, now close nipple and peddle up.
    Continue this procedure until all bubbles are free and clear.
    Keep an eye on the fluid tank to make sure it don't go low.
    This method is not the quickest and not always the most affective.
  4. Re: How to bleed a pd130 clutch help
    Mar 2016
    West Malling
    Bleeding the clutch because just feels touch spongy want to try this 1st that's all thankyou
  1. audi a3 AGU 1999 clutch cylinder bleed nipple
    By chris a3 agu in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-06-2014, 11:31 PM
  2. Best way to bleed brake and clutch fluid?
    By aerotec in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-02-2013, 12:42 AM
  3. How to bleed the clutch through??
    By leigh195 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-10-2011, 06:25 PM
  4. how to bleed my clutch ?
    By carlover in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2011, 02:19 PM
  5. Clutch bleed nipple- stripped thread
    By Yellow Peril in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-03-2009, 08:27 PM
