Thread: Golf 1.9TDI starting problems
  1. Golf 1.9TDI starting problems
    Hoping somebody can help to solve my cars starting problems. I am having extreme difficulty starting the car when it is cold in the morning. But for the remainder of the day it will restart straight away once it has been started in the morning.
    The glow plug light goes out almost immediately I turn the ignition key on. I had the RAC out to look at it but he was unable to sort it out and resorted to putting cold start down the air filter. The RAC man did however tell me that there was no power going to the glow plugs and that the glow plug relay was the most likely cause of this but as he could not find the relay he could not be certain.
    I have since located the glow plug relay (no 130) which involved removing the lower part of the dash and have since replaced the relay with a new one from VW.
    Still no joy. The car starts after several turns of the key and pumps of the accelerator pedal and results in a cloud of grey exhaust fumes - I am starting to worry in case I get a visit from friends of the earth or worse still Al Gore and my young daughter is moaning I am destroying the environment and causing global warning.
    Really don't know what to do next. I have the car booked in for end of next week with an auto electrician but would really like to sort it out before then if possible. Thanking you in anticipation
  2. Re: Golf 1.9TDI starting problems
    Aug 2007
    Northern Ireland
    Get it plugged into vag-com - sounds like possibly a temperature sensor fault. (Hence no power going to relay so no power coming from relay)
    Pete
    52 plate Golf GT TDi
  3. Re: Golf 1.9TDI starting problems
    Thank you for that bit of information, do you know where I can locate the temperature sensors, and would removing the sensor rectify the problem till I got it replaced. Once again thanks
  4. Re: Golf 1.9TDI starting problems
    Northern Ireland
    Hello, what model is your car ? Is it a PD engine or an older TDI ( 90 or 110 hp) i mite be able to help ya out .
  5. Re: Golf 1.9TDI starting problems
    The car is a 1.9TDI on an agn engine and it is 90 bhp if that helps.
    Regards
    Doug
  6. Re: Golf 1.9TDI starting problems
    Hi Think u got ur engine code wrong, is it not agr?in that case,check fuse (2) 50amp in fuse holder on your battery
  7. Re: Golf 1.9TDI starting problems
    Northern Ireland
    Yea just check the engine code again ..my car is a 2001 TDI 90 hp engine code ALH. Anyways sounds like ur static timing is just a little out ..u need to have it checked on vag com. The fuel pump is able to adjust its timing slightly when its running but the static timing is crucial for cold starts. if u try www.tdiclub.com and search for cold starting problem ..its a fantastic forum.
    Good Luck,
  1. Seat Alhambra 1.9TDI Starting Problems
    By atul in forum Alhambra
    Last Post: 27-07-2010, 05:59 PM
  2. Golf MK5 starting-up problems?
    By AndyF in forum Golf MK5 - 2004 - 2009
    Last Post: 07-02-2008, 06:42 PM
  3. MK 4 Golf starting problems
    By berksboy26 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-05-2007, 12:55 AM
  4. mk 3 golf starting problems
    By tward11 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 09:18 PM
  5. Audi A4 1.9tdi starting problems
    By sudderz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-11-2006, 07:26 PM
