Thread: turbo lag
Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. Re: turbo lag
    #31
    Jan 2016
    manchester
    thanks for all this mate hope its not going to be to bad and not costly
  2. Re: turbo lag
    #32
    Oct 2015
    GB
    That's ok, sometimes the code also could be ur turbo vanes clogged up with soot and needing a good wire brush and clean.
    The thing is if you guess then it becomes a money pit, best to really take it to a reptibile company unless u are knowledgeable yourself.
    A vcds is better than alot of the stuff of cheap auction sites and can pick up on better results.
    Sent from my SM-A300FU using Tapatalk
  3. Re: turbo lag
    #33
    Jan 2016
    manchester
    I keep reading on the web that it could be related to timing and you have to take the timing belt off to put on the new fuel pump , could it be that simple ?
  4. Re: turbo lag
    #34
    Oct 2015
    GB
    Not simple mate, a vcds will tell that too
  5. Re: turbo lag
    #35
    Jan 2016
    manchester
    hi mate
    thought id keep you posted, just had the wife's mate husband round and the actuator is not holding any pressure at all so fingers crossed it could be that.
    I also unplugged the maf and went for a drive and the car is the same to drive so it could be that too
  6. Re: turbo lag
    #36
    Oct 2015
    GB
    Sounds like ur on the right track mate
  1. Question turbo lag
    By bertb in forum New Member Introductions
    Last Post: 24-03-2016, 02:29 PM
  2. Turbo lag?
    By LaChris in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 26-02-2011, 10:28 PM
  3. Turbo Lag
    By lobs84 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-10-2008, 07:52 PM
  4. turbo lag
    By gazza3733 in forum New Member Introductions
    Last Post: 06-04-2008, 03:11 PM
  5. turbo lag
    By unhinged pastie in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2007, 04:36 PM
