Thread: turbo lag
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. Re: turbo lag
    #21
    Jan 2016
    manchester
    just took the car for a drive after cleaning the maf and now its going into limp mode
    my day is getting worse and its made no difference to the turbo lag
    getting a reading now of
    turbocharger supercharger under boost
  2. Re: turbo lag
    #22
    Oct 2015
    GB
    Do a code read mate
    Sent from my SM-A300FU using Tapatalk
  3. Re: turbo lag
    #23
    Oct 2015
    GB
    Take the battery out for five mins then put back in, may reset the fault
  4. Re: turbo lag
    #24
    Oct 2015
    GB
    Cleaning A Mass Air Flow Sensor To Stop Hesitation - YouTube
  5. Re: turbo lag
    #25
    Nov 2008
    get a proper scan done with vag com and post the results on here.
    2008 Audi A6 2.0 tdi s line avant. BRE engine. 19" le mans alloys, bluetooth, sat nav,full leather
    0 2 0
  6. Re: turbo lag
    #26
    Jan 2016
    manchester
    the code is p0299
    looking on the web it could be anything mate
  7. Re: turbo lag
    #27
    Oct 2015
    GB
    Ross-Tech, LLC
    881 Sumneytown Pike
    Lansdale PA 19446, USA
    Tel: +1 267 638 2300
    Fax: +1 215 893 3816
    ShopInfoF.A.Q.Download/UpdateManualUpgradesLiteratureSearch:**
    16683/P0299/000665
    Contents*[hide]*
    1*16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached1.1*Possible Symptoms1.2*Possible Causes1.3*Possible Solutions1.4*Special Notes1.4.1*Gasoline1.4.2*Diesel16683/P0299/000665 - Boost Pressure Regulation: Control Range Not ReachedPossible SymptomsReduced Power OutputLimp ModePossible CausesHoses/Pipes incorrect connected, disconnected or leakingCharger Pressure Control defectiveTurbocharger faultyDiverter Valve faultyPossible SolutionsCheck Hoses/Pipes to/between ComponentsCheck / Clean / Replace Charge Pressure ControlCheck TurbochargerCheck Diverter ValveSpecial NotesIf the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.GasolineWhen found in*2.0l TFSI:Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).RoW vehicles see: TPI 2016331 for details.NAR vehicles see: TSB 01-07-70 or 2013392 for details.When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure:*P2279,P1136,*P1297,*P1093*and/or*P0507.When found in*Audi A4/S4/RS4/Cabriolet (8K): 2.0l (CAEB):See TPI 2031245/6 - turbocharger excessive waste-gate play.DieselWhen found in*VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):Verify the mechanical part of the Exhaust Valve Control Module (J883) is not seized or binding.When found in the 1.9 L TDI-PD (BLS):Check vacuum supply from the vacuum reservoir located in the valve cover for leaks. Using a vacuum gauge, wiggle the valve cover and hose connections to check for a leak. The following photo was submitted from a customer working on a 2010 VW Caddy (2K chassis) with this*vacuum reservoir problem.
    Category:*Fault Codes
  8. Re: turbo lag
    #28
    Oct 2015
    GB
    Vag com website, put in your generic code for more info and good luck
  9. Re: turbo lag
    #29
    Jan 2016
    manchester
    how do I do that mate ?
  10. Re: turbo lag
    #30
    Oct 2015
    GB
    Type in Google your vag code,
    It will show a link to vagcom
  1. Question turbo lag
    By bertb in forum New Member Introductions
    Last Post: 24-03-2016, 02:29 PM
  2. Turbo lag?
    By LaChris in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 26-02-2011, 10:28 PM
  3. Turbo Lag
    By lobs84 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-10-2008, 07:52 PM
  4. turbo lag
    By gazza3733 in forum New Member Introductions
    Last Post: 06-04-2008, 03:11 PM
  5. turbo lag
    By unhinged pastie in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2007, 04:36 PM
