Thread: What's that button there do?
Results 1 to 10 of 14
  1. What's that button there do?
    Mar 2016
    Windsor
    Alright John got a new motor?
    My Avant Ultra was delivered today. I noticed a keypad next to the gear lever with numbers 1-8. It's obviously not for the phone unless you never call anyone with a 9 or 0.
    When you press them it says something like "this button not active" on the screen. Any idea what they're for? Don't make me read the manual.
  2. Re: What's that button there do?
    Feb 2010
    In the middle
    It's the radio presets. Tune into your favourite radio station, then press and hold and it'll store the station.
    I think it works for the phone as well, but I've not tried that as yet.
    A4 (B9) Ultra Sport. 150ps Diesel S-tronic. Glacier White
  3. Re: What's that button there do?
    Oct 2015
    Wetherby UK
    They are pre-sets, I have mine set for phone numbers, but you can set them for radio saptations. Display the phone number / radio station on the main screen and press and hold the button to store the item, might work for a sat nave address too, but I've not tried that
  4. Re: What's that button there do?
    Mar 2016
    Windsor
    Quote Originally Posted by Vizen2 View Post
    Any idea whether it works with the telephone numbers in CarPlay or just via the BT connection?
    It's annoying that the car won't do both connections because I'm used to calling from the steering wheel but I'll be using Spotify etc. within CP.
    0 0 1
  5. Re: What's that button there do?
    Feb 2010
    In the middle
    From what I can work out, it's either CarPlay or the Audi MMI interface for phone use. CarPlay doesn't need bluetooth to be on.
    It is a bit frustrating when you need to switch between the 2. Must admit, I'm tempted to disable CarPlay on my phone as I don't think it adds that much to the user experience. I use Napster, and that's available through the Audi MMI (however, you do need to have the app open on your phone).
  6. Re: What's that button there do?
    Feb 2016
    Aberdeen
    On my current BMW you can set the shortcut keys to do anything in the iDrive menu - show tyres pressures, turn the display off etc. Just navigate to the option you want, hover over it and hold down the shortcut button and it will assign that command to the shortcut.
    Not sure if the B9 does the same?
  7. Re: What's that button there do?
    Mar 2016
    Crowborough UK
    Quote Originally Posted by ILikeJam View Post
    Can the * button on the steering wheel not be assigned to any function? Thought it could but maybe wrong?
  8. Re: What's that button there do?
    Oct 2015
    Wetherby UK
    I agree, not sure what CarPlay adds, it disables the MMI phone system, including the preset buttons, the display is, imo, low quality, and to get back to it from another function you need to go through the main menu system. Told my iphone to for my car yesterday but it still connected automatically when I plugged into the USB port, do I'm currently using the rear 12v socket to charge the phone.
  9. Re: What's that button there do?
    Mar 2016
    Windsor
    Unfortunately not, just radio. A shame as adding things like nav shortcuts or music playlists would be quite useful.
    Regarding CarPlay I found a problem this morning when listening to a podcast. The podcast ended and I tried to play something on Spotify but it wouldn't select anything from the menu and just kept playing the podcast.
    Another problem I've found is with the Audi Connect. It doesn't (seem to) automatically use the phone's connection and keeps demanding I put a SIM in the slot, something I'll never be doing.
  10. Re: What's that button there do?
    Feb 2010
    In the middle
    Quote Originally Posted by Schmy View Post
    I have managed to assign a phone number, location and radio station. You need to have the relevant screen on the MMI, then press and hold the numbered button.
    Agree, 100%. I wish there was a way to disable the message.
  1. AC Button not lighting up. Toggle button not working.
    By Dar123 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-02-2016, 11:53 PM
  2. AC Button not lighting up. Toggle button not working.
    Last Post: 06-02-2016, 08:33 PM
  3. Replies: 2
    Last Post: 30-10-2014, 02:37 PM
  4. Replies: 0
    Last Post: 02-11-2007, 05:36 PM
  5. 2 button and 3 button fobs / remotes
    By Loofer in forum Archive posts
    Last Post: 07-08-2007, 02:08 PM
