Thread: Multiple Cylinder Misfires on Audi A4
  1. Multiple Cylinder Misfires on Audi A4
    Feb 2015
    London, UK
    Hey Guys,
    I've recently had the Emission Control System light on my dashboard turn on briefly in my Audi A4 Cabriolet (2004, V6).*
    It turns on and then off again.
    I've read the fault codes but am not that knowledgable so was hoping you guys could give me an idea what I'd have to expect if I were to bring it down to a mechanic. A vague idea whether it's a minor issue or potentially expensive would be great. And whether there is any DIY I could do on it?
    When I delete the codes some of them come back usually the 7 below.
    The car drives a bit jerky sometimes but overall works relatively alright. I've stopped driving it for now until I find out more.
    Looking forward to any help/advice I can get. Thanks guys.
    Please find the fault codes listed below with a link to Ross-tech:
    16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
    http://wiki.ross-tech.com/wiki/index...4/P0300/000768
    16685/P0301/000769 - Cylinder 1 Misfire Detected
    http://wiki.ross-tech.com/wiki/index...5/P0301/000769
    16686/P0302/000770 - Cylinder 2 Misfire Detected
    http://wiki.ross-tech.com/wiki/index...6/P0302/000770
    16687/P0303/000771 - Cylinder 3 Misfire Detected
    http://wiki.ross-tech.com/wiki/index...7/P0303/000771
    16688/P0304/000772 - Cylinder 4 Misfire Detected
    http://wiki.ross-tech.com/wiki/index...8/P0304/000772
    16689/P0305/000773 - Cylinder 5 Misfire Detected
    http://wiki.ross-tech.com/wiki/index...9/P0305/000773
    16690/P0306/000774 - Cylinder 6 Misfire Detected
    http://wiki.ross-tech.com/wiki/index...0/P0306/000774
    Recently when trying to check it I've also had the following code show up instead of the Cylinder 4 misfire:
    16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
    http://wiki.ross-tech.com/wiki/index...5/P0441/001089
    Last but not least occasionally have gotten the following fault codes as well:
    18149 - I believe this one means "Clutch Pressure Adaptation: Limit Reached"
    18181 I believe this one means "Hydraulic Pressure Sensor 1 too large"
    If you require any other information please let me know.
    Thanks again!
    -Mark
  2. Re: Multiple Cylinder Misfires on Audi A4
    Jul 2007
    glasgow
    35 Post(s)
    change all the spark plugs firstly
    then look at coil pack(s) depending on what you have fitted
  3. Re: Multiple Cylinder Misfires on Audi A4
    Feb 2015
    London, UK
    Thanks for your reply Niall, I will take that into account when seeing my mechanic in the countryside next week Thursday. Will be busy with work until then. I will not be driving it until then.
  1. Please Help audi a4 2.0 fsi Missfire in cylinder 4 and multiple missfires fault !
    By Rogerout in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2014, 05:08 PM
  2. Multiple Misfires Detected
    By warp_speed in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-03-2010, 02:18 PM
  3. Multiple Cylinder Misfire
    By CYLax in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-11-2008, 10:49 PM
  4. Multiple cylinder misfires! (Random)
    By AndrewB648 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 09:34 PM
  5. Random/Multiple Cylinder Misfire Detected
    By mercaudi40 in forum A8 - S8 - V8
    Last Post: 23-01-2008, 05:46 PM
