Thread: Audi Q7 3.0 TDI headlight upgrade
  1. Audi Q7 3.0 TDI headlight upgrade
    Mar 2016
    Essex
    Hi all,
    Recently joined forum after buying a 2010 3.0 TDI SE Quattro.
    Really pleased with the car, but it hasn't got the DRL / LED headlights. Apologies if I'm going over old ground, but does anyone know if I can upgrade the current lights (front) to the newer led ones? Being a 2010 would CCM and ballasts etc be compatible with the newer lights? I've been offered a set at a reasonable price, just wanted to check with those in the know before committing.
    Any advice appreciated. 👍
  2. Re: Audi Q7 3.0 TDI headlight upgrade
    Jun 2015
    Glasgow, Scotland
    You can upgrade them. Over the last 2 yrs retrofits of the light system front and rear have become much more abundantly available, and at more affordable rates.
    I would advise though, that if you are gonna upgrade the lights, make sure you do the front and the rear, and the led front indicators too. It will give a much better overall look. Rather than a facelifted main headlamp unit paired with the old indicator strip and old rear light unit...
    Good luck! 😉
    Sent from my SM-N910F using Tapatalk
  3. Re: Audi Q7 3.0 TDI headlight upgrade
    Mar 2016
    Essex
    Thanks for the reply. The rear lights are already the latest ones strangely, as are the front indicators, all of these are led, which makes me wonder why the headlights aren't, perhaps it was an option?
    Do you know if ballasts / control units for the headlights are plug and play, or do these need changing also?
    Thanks again.
  4. Re: Audi Q7 3.0 TDI headlight upgrade
    Apr 2009
    You'll have halogen lights. Xenon lights were standard only with the S-Line at that MY.
    It should be fairly simple to replace them with the Xenon units, but you'll need bulbs and ballasts to go with them. It depends whether the existing module would support the LEDs. I would think it would, requiring just a VCDS mod to enable it.
    It would definitely be easier that retrofitting to a pre-facelift Q.
    HTH
    Current: 2012 Q7 S-Line
    Previous: 2011 A6 Avant 2.0TDi S-Line Special Edition; 2007 Q7 3.0TDi Quattro S-Line; 2006 A6 3.0TDi Quattro S-Line Le Mans; 2005 A6 2.0TDi SE
  5. Re: Audi Q7 3.0 TDI headlight upgrade
    Mar 2016
    Essex
    Thanks for the info, that explains why the fronts are halogen. I'll have a word with Audi and see what they would charge for a VCDS re-programme, and take it from there.
    Thanks again,
    John.
  6. Re: Audi Q7 3.0 TDI headlight upgrade
    Feb 2014
    Cork, Ireland
    Might be worth trying Kufatec
  7. Re: Audi Q7 3.0 TDI headlight upgrade
    Apr 2016
    coventry
    I've just had my 2009 pre facelift with halogens upgraded to the rear leds, plus the newer xenon with drls on the front. a guy called ash done mine for £200 (i supplied all parts) he's based in kent, goes under the name audiretrofits.( http://audi-retrofits.co.uk ) pictures of his work done etc on instagram, i liked his work i seen online that i drove 2 hours from coventry to get him to do the work
    you may find you will also need new "headlight carriers" for both sides i did, see here:Audi Scheinwerferhalter absorption Facelift 2010 Onwards Right: Amazon.co.uk: Car & Motorbike
    also a halogen to xenon adapter harness: Bi Xenon HID Headlights - Adapter- Audi Q7 DRL WIRING loom harness Cable | eBay
    then coding in, possibly some mods to the control board located near drivers side footwell, worth the effort thou and i recommend ash to do the work if you can get the parts cheap
  1. Audi Allroad 2.5tdi 2004 model headlight upgrade to xenons
    By taggart in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-10-2015, 10:00 AM
  2. SE headlight upgrade
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-02-2015, 07:40 PM
  3. Audi A4 b5 headlight upgrade
    By themullet in forum Body Work, Body Styling and Body Kits
    Last Post: 11-06-2012, 08:44 PM
  4. Question Headlight upgrade
    By elPaulio in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-10-2008, 07:48 AM
  5. B5 Headlight upgrade
    By Derek Audi 1.8T in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-04-2008, 11:44 PM
