Thread: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
Results 1 to 10 of 15
  1. Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Dec 2015
    Scotland
    11 Post(s)
    Hi Folks,
    I have a 1.6 tdi 2012 passat estate.
    Project this weekend is to do the rear discs etc, was watching the Ross Tech video and it says to attach a charger to maintain the batt voltage which is required by one of the epb modules or else it will create problems.
    What kind of charger can I use, I understand my car uses a AGM (Absorbed glass mat) battery and this may need special charging!?
    What a pita this is my B7 is a great car but the EPB is a joke I hate it, I just want to do the rear discs and pads and have to go through all this faff before even taking anything appart!
    Any help appreciated with charging or any tips on changing the rear brakes!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Pembrokeshire
    22 Post(s)
    lol, you need to keep a steady voltage when you unwind the calipers. if the battery is good then you probably won't need a charger, but to be on the safe side because the ignition is on and you have a computer connected, just connect any charger, even a really old fashioned one. you are not charging the battery as such so it doesn't matter. its just if the voltage gets too low it causes grief. i don't know what grief as i have never done it without a charger connected.
  3. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Jan 2016
    Winchester Hants
    29 Post(s)
    BatteryStuff Articles | Compare and Contrast Between AGM and Gel Batteries
    If concerned about charger or charging give them a call.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  4. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Jul 2007
    glasgow
    35 Post(s)
    you could buy an autel vag505 and rewind the brakes the proper way, around £80- 110 .
    its also a code reader and will reset your service light etc
    I swear by it, others swear by vcds ( in which I wish I could buy ) but if your on a budget, the autel is hard to beat
  5. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Dec 2015
    Scotland
    11 Post(s)
    Sorry I should have said I'm using a vcds, I don't know how you could do the job otherwise!
    I understand with certain newer vags you need to maintain the voltage as described above, I don't think (but may be wrong) that any old charger will do because Agm batteries charge quicker than normal batteries so even a short time could do damage!
    Some people leave the engine running which I don't fancy work in and around the exhaust fumes!
    I will not be beaten by this total nonsense!
    Will repost what happens, any other feedback appreciated!
    Knowing my luck one of the disc retaining screws will have seized!
  6. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Jan 2016
    Winchester Hants
    29 Post(s)
    What mileage are we talking about before they need changing.
    My old Audi A4 1998 at 145k, only had two sets in that time. Though I replaced them I suspect had I had them changed by a garage it would have been cost effective.
    Do we know how much a garage would charge to change them on an EPB vehicle.
  7. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Dec 2015
    Scotland
    11 Post(s)
    Vw is £290 and budget Indy with crap parts is £160 both for pads and discs.
    Trw is oem parts, I'm using pagid which I've found good in the past. £74 for parts from ecp.
  8. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Jan 2016
    Winchester Hants
    29 Post(s)
    As you already own VCDS you have removed much of the cost so its just your time to do the work. I suspect you are more than adequately suited for the job and may well enjoy it at the end of the day...lets hope it does not take that long.
    For me it appears the Vag505 will also release the mechanism but having checked there are dangers involved in even buying a genuine one to start with. Then a good AGM charger must be sourced which yet again one would have to tread very carefully with when sourcing.
    I have two local VW specialist so may get a few prices from them to compare.
  9. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Jul 2007
    glasgow
    35 Post(s)
    in the autel vag505 , its a simple job. Its just rewind and that's it
    However getting the 2 bolts off on each side is a nightmare, on a 2008 model anyway. The bolts are really, really tight and hard to get into, with almost 20% turn available.
    After the epb rewinds, then you have to screw in piston.
    Merry Tools HK Brake Caliper Piston Wind-Back Rewind Double End Tool For Ford Audi VW 449773: Amazon.co.uk: DIY & Tools make sure its right handed and then you need this
    Brake Calliper / Piston Wind Back Rewind Adapter for VAG VW Audi AT330: Amazon.co.uk: Car & Motorbike
  10. Re: Rear discs and brake pad change on 2012 B7 Passat - maintaining voltage / charging
    Jan 2016
    Winchester Hants
    29 Post(s)
    That £290 alone is sounding good.
    I emailed my local VW specialist (not dealer) with all the details of my Passat to provide a quote and they emailed back...please phone to discuss. I shall not be using them for anything.
    In short when the time comes I will have my local VW dealer do it.
  1. Brake clunk after front pad and discs change
    By Shab2015 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 10-10-2015, 06:37 PM
  2. B6 Passat Rear Pad Change
    By BobTheRocker in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-06-2014, 02:33 PM
  3. Question Rear brake discs and pad change Q?
    By go-for-it1 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2013, 11:25 PM
  4. Passat B6 (3C) Rear Brake pad change - VCDS problem
    By dmcentire in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-04-2012, 06:50 PM
  5. Rear Brake pad change.
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2007, 03:24 PM
