Thread: Washer Pump Madness.
  1. Washer Pump Madness.
    Hi Folks
    New to the forum - just bought a 1990 LT28.
    The washer pump is not working HOWEVER, when I put a multimeter across the terminals that feed the pump it reads 12.5v (when washer switch activated). When I connect the pump directly to the battery it works fine. But when I connect the pump to the terminals and try to operate using the washer switch the pump does no operate at all.
    Any ideas anyone???
    Its definately not the wiring terminals as Ive cleaned them, bypassed them with wires and taken multimeter readings from all points. Also tried using different earth but this didnt help.
    Stoooooo
  2. Re: Washer Pump Madness.
    Dec 2007
    Montrose Scotland
    Stooo , is the pump itself jambed? does the motor work when removed from the pump or attached?
  3. Re: Washer Pump Madness.
    Madness indeed...
    heres a suggestion...
    maybe the brushes are going/ spindle has become loose so when you hold it to the battery the brushes make contact but when you mount it on the bracket by the water resevoir the different plane (angle its at)causes the spindle/brushes to move apart???
  4. Re: Washer Pump Madness.
    ignoe that sorry, i didnt realise you posted in october 07.. bit late now!
  1. Headlamp washer pump knackered!
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-11-2011, 01:44 PM
  2. seat madness
    By STORM 2 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-09-2007, 05:30 PM
  3. Pressure Washer
    By prolfe in forum Chat - Completely Off Topic
    Last Post: 30-08-2007, 05:49 PM
  4. 02 A6 Washer Leak
    By akh747 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-07-2007, 04:00 AM
  5. Help please Re: Rear washer jet.
    By Big_E in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:29 PM
