Thread: Egr delete pd 150
Results 1 to 10 of 16
  1. Egr delete pd 150
    Dec 2008
    What's the way to do it without the delete pipe ?
    I want to retain the anti shudder valve and also have the darkside hard boost pipe kit with egr attached so don't want to cut the ally pipe
    Can I simply clean egr and leave everything in place and just block the vacuum line? I can map it out of the software if needed
    Please advise thanks
  2. Re: Egr delete pd 150
    Pembrokeshire
    22 Post(s)
    yes, thats the way to do it. remove the pipe between egr valve and manifold and blank either end with blanking plates.
  3. Re: Egr delete pd 150
    Dec 2008
    What about the egr cooler that all just stays as it is ?
  4. Re: Egr delete pd 150
    Pembrokeshire
    22 Post(s)
    you can remove that and join the coolant pipes together.
  5. Re: Egr delete pd 150
    May 2012
    Everywhere
    308 Post(s)
    Disable by pluging egr vac line .
    Only 1 blank required ( optional ) at exhaust manifold end as egr end the egr plunger is in a closed position when disabled.
    What year and plate ?
  6. Re: Egr delete pd 150
    Pembrokeshire
    22 Post(s)
    presuming egr actually seals 100%. for the sake of a 2.99 blanking plate i always fit one.
  7. Re: Egr delete pd 150
    Dec 2008
    Can I just leave the egr cooler and the lines as they are ?
    So just plug the vacuum line at top of egr with screw
    And fit blank to egr and exhaust manifold side ? We're can I buy the blanks ?
  8. Re: Egr delete pd 150
    Dec 2008
    2005 seat Leon 1.9 of pd 150
  9. Re: Egr delete pd 150
    Pembrokeshire
    22 Post(s)
    yes, you can do that and leave it all in place.
  10. Re: Egr delete pd 150
    Dec 2008
    Thanks for replies , were can I buy just the blanks without kit?
    What your views on single mass flywheel conversion? Does it break the gearbox ?
  1. 3.0TDI EGR delete?
    By brummieboy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-05-2014, 04:27 PM
  2. Question ASZ 130BHP have an EGR Cooler and what size EGR delete kit do i need? 51mm or 57mm?
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 30-10-2013, 12:54 AM
  3. allard egr delete and breather kit on a 150 pd tdi bora
    By j13hna in forum 1.9TDi - Engine
    Last Post: 10-12-2011, 05:28 PM
  4. EGR delete
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2011, 09:58 AM
  5. egr delete ???????
    By PAT_GT_TDI in forum Golf MK4 - 1999 - 2004
    Last Post: 13-01-2010, 05:13 PM
